#1 |
I'm sure all of you have covered the details of a trannie swap, but I'm nervous as all holy hell about it, because... car electronics scare me. What problems will I have to tackle during a trannie swap? I plan on disassembling the trannie and putting whatever parts I have to put in there to make it worthwhile, and I'm also considering taking appart the lower half of the engine to replace bearings. I'm just really scared of ****ing up my car doing this after ****ing up the Hi/low beams mod...
Thanks for any info. |
#2 |
There are very litte electronics involved in a tranny swap.
#3 |
![]() Join Date: Jun 2005
Well may I ask you what are you putting in there vice what you already have? Or is it the same tranny just replacing it?
#4 |
MP7 to MP3. I need help with knowing stuff, like the engine cradle and such, so I know what to take out first.
#5 |
Remove transaxle mount-to-cradle nuts. (15mm socket needed)
Remove steering rack to cradle nuts (1/2" socket needed for bolts, 15mm socket needed for nuts). The bolt nearest the transaxle may not come out. Remove the nut and leave the bolt there until the cradle is removed. Remove the brake line bracket plastic rivet at the rear of the cradle. These are confusing for me. Any help would be appreciated. Note: Either use pictures or be VERY detailed! I haven't gotten further than this, so I'm not sure what else will confuse me. |
#6 |
#7 |
so about how much is it to have a shop swap an auto for a manual? would this be done at saturn or at another shop?
#8 | |
![]() Quote:
www.streetdesignauto.com and had it done for $220. Add on to that the gas and the clutch and fluid and I saved about $300 - $400 dollars.
2008 Dodge Grand Caravan. 2008 Nissan Altima 1970 Mercury Cougar: 351C, 4spd. Classic for shows. 2005 Subaru Impreza 2003 Grand Marquis |
#9 |
Niiiiiiiiiiiiiiiiice.
Except I live waaaaaaaaaay out in BFE, man. SDA is too damn far away for me. ![]() |
#10 | |
![]() Quote:
for the first time in 8 years, I don't own a saturn. |
#11 |
where are the sda guys located
#12 |
Well, it's actually been pretty easy so far. It's just the damn control arms that are causing all the problems. I'll probably head out there again to try s'more... *sighs* Yes, it's a tough job after all.
#13 |
![]() Join Date: May 2005
Tranny pull/swap on a saturn=teh eaaaaasy...
IF you have all the right tools before you start. |
#14 | |
![]() Quote:
#15 |
Thanks a lot, you guys. It seems the project will _eventually_ get done. There will be very large obstacles in the way. Now, I'm having trouble removing the downpipe from the manifold. Any suggestions? The studs/bolts are so rusted in, they're being a PITA to remove.
#16 |
I cut mine, 'cause I was putting a new header in anyway, but if you are keeping yours intact, the only thing is to soak the studs real good w/ a good penetrant like liquid wrench. then, get a new 6 point socket on there (is it 13mm?), a long extension bar, and a good long breaker bar on there. if the socket is on there tight, you should be able to break it loose. you may also snap the stud. in that case, pull the manifold off the engine and drill out the studs. I wouldn't try to drill them out w/ the manifold still installed.
#17 |
Good advice. Now, I'm in the process of removing the axles (and replacing the front brakes while I'm at it
#18 |
![]() Join Date: Nov 2004
i threw my clutch fork through my bell housing from side stepping the clutch and had to do a trans swap back in december. it was no problem, and my car still shifts like a dream.
#19 |
Kickass. For an update for those who give a %$&@, I'm down to simply dropping the auto and getting started on the manual. It's been a 5-day thing so far, and it's probably going to end on the 7th day. Brakes and such will come later.
Bookmarks |
Major Trannie Issue...reverse! | saturn94v | S-Series Tech | 1 | 04-02-2008 01:23 PM |
Nervous Tach | RAG man | S-Series General | 0 | 06-21-2006 09:43 AM |
nervous | snowwhite | Ion Tech | 20 | 02-24-2006 05:50 AM |
getting nervous...new Vue almost here | Florida Girl | Vue General | 28 | 11-06-2005 09:08 AM |
Engine Swap or trannie swap | SL-2er | Miscellaneous Tech | 1 | 04-28-2003 05:00 PM |
