Old 04-17-2009, 07:31 PM   #1
ifried85
ifried85 is on a distinguished road
Default Stuck radiator drain plug
I am trying to drain my coolant to replace my engine coolant thermostat but I can not seem to open the radiator pet cock. Is there any tool I can use that will not break the petcock or should I just take off the lower radiator hose?
ifried85 is offline   Reply With Quote
Old 04-17-2009, 08:21 PM   #2
Default Re: Stuck radiator drain plug
Give it a good squirt of your favorite penetrating oil. Let it sit for a few minutes and try it.
Also seeing as your are replacing the t-stat remove the block drain bolt under the t-stat (block side) and let the coolant drain that way.
Old 04-17-2009, 09:14 PM   #3
ifried85
will removing the block drain bolt remove all of the coolant or just some of it?
Old 04-17-2009, 09:23 PM   #4
off-track
off-track's Avatar
You do know its not like a regular petcock but a 1/4-1/2 turn counter clockwise and pull towards the rear right?
http://www.saturnfans.com/photos/sho...hp?photo=49868
Purchased 114k 10/07
Added OEM CC
Old 04-17-2009, 09:52 PM   #5
The block drain does not drain much unles your thermostat is closing properly. Just take off the lower radiator hose and catch it all in a big pan. Hog pan works very well. The radiator drain is prone to break and then its new radiator time. The instructions above are critical to getting it open.
Old 04-17-2009, 10:14 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
use needle nose pliers and press and twist to open the radiator drain plug. and you need to remove the drain plug on the engine under the thermostat. both need to be removed to drain all the coolant.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-18-2009, 03:26 AM   #7
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
I was also unsuccessful at removing the petcock when I was replacing my water pump, but I later learned from reading on this site that you can use a ratcheting box wrench. I forgot the exact size, but it's on the order of 20mm. Also, if you are facing the front of the car, you would twist clockwise from your perspective to make the petcock rotate counter-clockwise from the perspective of directly facing the petcock.
edlee is offline   Reply With Quote
Old 04-18-2009, 06:43 AM   #8
spencerforhire
spencerforhire will become famous soon enough
spencerforhire's Avatar
2001 SC1
The plastic petcock only has to move about 1/4 of a turn from closed to open, and comes out about 1/2". You have to pull out at the same time as you turn.
01 SW2-#1 son's
01 SC2-#2 son's
00 SW2-wife's
00 SL2-daughter's
99 SW2-mine
00 SL1-spare
98 SC1-parts
+ 25 scrapped
Visit www.spencerforhire.ca to see what I do other than fix Saturns
spencerforhire is offline   Reply With Quote
Old 04-18-2009, 01:46 PM   #9
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Lower radiator hose is easier IMO
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
mr18436572 is offline   Reply With Quote
Old 04-18-2009, 01:50 PM   #10
The block drain bolt and the radiator drain plug may be left alone if just changing the thermostat. Just remove the lower radiator hose. If the block does not drain because the thermostat is actually closed, remove the thermostat housing.
Once the lower hose is removed pouring hot water over the radiator drain valve helps.
Radiator drain plug wishihadacamaro S-Series Tech 6 11-16-2008 12:27 AM
Radiator drain plug leak rreuben S-Series Tech 12 09-19-2007 01:07 PM
radiator drain plug leak wojtek_f S-Series Tech 0 08-11-2007 05:33 PM
help!!!!!!trans drain plug stuck goldsl2 S-Series Tech 3 05-29-2005 02:32 AM
Dumb radiator drain plug SLeepr Miscellaneous Tech 3 03-26-2003 12:34 AM
