Old 10-10-2007, 01:24 PM   #1
AJT_Leo
AJT_Leo is on a distinguished road
AJT_Leo's Avatar
Default SDA dogbone mounts vs mount inserts
Hi all,
I'm thinking of replacing my current dogbone mounts. They are the original mounts, and at 11 yrs old, I figure they need replacing. SDA sells the dogbone mounts at $99 for 2. Which would be better, buying the dogbones from SDA, or buying the mount inserts and using my existing dogbones. I don't have a vise or press to help install the inserts. I found instructions somewhere that showed using a vise when installing the inserts. Has anyone installed them without using a vise or press? In terms of build quality, are the SDA mounts better made than stock? I could buy new stock mounts; I found them at getsaturnparts.com at about $75 for one mount, so 150 for 2. SDA's mounts are cheaper, but the inserts would be even cheaper than the new mounts. Please advise.
kthxbai
The bureaucracy is expanding to meet the needs of the expanding bureaucracy.
AJT_Leo is offline   Reply With Quote
Old 10-11-2007, 12:59 AM   #2
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
Default Re: SDA dogbone mounts vs mount inserts
I just got the SDA dogbones today in the mail to replace my stock mounts. Gonna report back tomorrow when they are installed
plastic torpedo is offline   Reply With Quote
Old 10-11-2007, 09:08 AM   #3
tarsun
tarsun is on a distinguished road
i dont have the SDA's but i do have the inserts from summit racing.
http://store.summitracing.com/partde...5&autoview=sku
i like 'em alot. i think there great. i chose these because of two things.
A) i heard alot about the dog's breaking. (all speculation)
B) and the inserts were cheaper... so that just sealed the deal
tarsun is offline   Reply With Quote
Old 10-11-2007, 09:08 AM   #4
AJT_Leo
AJT_Leo's Avatar
Good deal. I'll be happy to read your thoughts.
Old 10-11-2007, 09:09 AM   #5
AJT_Leo
AJT_Leo's Avatar
How did you install the inserts into the factory mounts? Did you use a press or vise? I have neither, so I don't know how else I could install them.
Old 10-11-2007, 09:15 AM   #6
The after market ones that break, were/are, in a sense, broken from the "factory." They just gave that big "loop" a hook so it was only connected on one end/side unlike the stock ones that have the loop that connects on both sides. Someone posted pics comparing the two a while ago.
Old 10-11-2007, 10:51 AM   #7
Luke
Luke's Avatar
Default Re: SDA dogbone STRUTS vs STRUT inserts
Fm > AJT Leo
dogbone > >Struts
dogbone > > struts
SDA struts
struts.
The entire Saturn "Powertrain Mounting System" is called "Torque Axis Mount System" [TAMS]
The engine and transmission mounts, support the >weight< of the powertrain,
while the engine strut and transmission strut, control the >torque< motion.
Luke is offline   Reply With Quote
Old 10-11-2007, 11:02 AM   #8
AJT_Leo
AJT_Leo's Avatar
Yes, yes, understandable. I was going to put struts, but then I figured that I'd be typing out strut mounts or some such, and I would then confuse myself.
Old 10-11-2007, 08:14 PM   #9
tarsun
i used a vice...
bit of a pain but i got it..
and what (fetchitfido) are you talking about?
Old 10-11-2007, 09:25 PM   #10
boatmoter
boatmoter is on a distinguished road
boatmoter's Avatar
1993 SL2
ADVANCE AUTO HAS THE STRUT MOUNTS THAT ARE SOLID,TAKEM OUT OF THE BOX & INSTALL.. MAYBE TOO EASY FOR A LOT OF YOU.. GO TO THE ADVANCE ON THE NET,LOOK AT THE CATALOUGE,AND LOOK AT THE TWO DIFFERENT ONES,ONE IS OEM STYLE AND THE OTHER IS SOLID. LOOKED LIKE $38.00 EA. BEFORE GOING TO THE ADVANCE STORE i WOULD TAKE A PRINT OF THE PART FROM THIER SITE,THEY MAY NOT KNOW WAT YOU WANT..
boatmoter is offline   Reply With Quote
Old 10-11-2007, 09:26 PM   #11
AJT_Leo
AJT_Leo's Avatar
Fetch is describing the way the aftermarket struts are made. The OEM struts appear to be a single, thick loop of steel that is pressed in the middle to create the dogbone. The aftermarket struts (anchor, pioneer) appear to use a thinner piece of steel that is bent to form the dogbone and then welded at one point to finish the loop. The weld point is the weak spot and based on past pictures the aftermarket struts break at that spot.
Hmm, as for you using a vise that is not good for me. I don't have a vise. I will probably use the SDA struts instead. But, I'll wait to see what Plastic reports.
Old 10-11-2007, 11:32 PM   #12
plastic torpedo
2000 SL2
1994 SC2
A word about SDA
Look at the difference between SDA (right) and AdvanceAuto (left)
See the difference in size, thickness and welding technique? That's why I went with SDA.
I got them installed today, it's awesome! Shifting is A LOT easier, and it's hard to describe the vibration. The car isn't "shaking" inconsistently like it used to with stock mounts. Nothing rattles, it's just a smooth vibration from a smooth running engine. I'm super happy.
I have both the upper mount and two lower dogbones with SDA, and the car is rattling less than stock and feels a lot more solid.
Oh, where did the wheel hop go? I can actually launch now! woohoo!
Old 10-12-2007, 02:50 PM   #13
AJT_Leo
AJT_Leo's Avatar
Good deal, Plastic. I think I will buy the SDA versions. I have a replacement lower mount, and I'll wait until I have the dogbones, and replace all three at once. I already have a new upper mount, albeit a corteco aftermarket version; not the 1st design.
Did you have any trouble installing them? Like the engine moving once the old ones were disconnected? Or was it just jack/lift the engine and swap out?
Old 10-12-2007, 03:55 PM   #14
tarsun
these are NOT aftermarket... there stock mounts with aftermarket inserts.
different years had different designs.
there were aluminum ones like this...
there were the ones that came of of my car like this
and then theres these.
ALL stock
BUT I didn’t know that autozone sold mounts like that.
That’s probably where all the neg feedback came from…
Old 10-12-2007, 06:28 PM   #15
amazinghl
Get the insert it, you'll need the vise, BIG hammer, socket set, vise grip and grease.
Forget it if you don't have all have above.
00 Insight 72mpg
Old 10-12-2007, 10:35 PM   #16
plastic torpedo
2000 SL2
1994 SC2
Putting in the SDA mounts was one of the easiest things I've ever done. Timewise, it had to be one of the best mods per minute spent
The tranny mount was replaced in 2 minutes. You have to push the tranny back about 1/8 of an inch to get the bolt in - poof done.
The engine was a bit slower and took around 10 minutes, but all you have to do is jack up the car on passenger side, take off the wheel and splash guard. Take off the metal bracket that holds the lower engine mount. Take off the mount (with the bracket). Slide the SDA mount in the bracket, and put it all back in. There was no adjustment required, everything "just fits" without moving the engine.
Today I tried a couple "harder" launches to see if it really did get rid of wheelhop, and all I could hear was my tire burning out, no wheelhop at all! I know I know - diff pin. I'm not doing it again. But I had to see
I'll never have another saturn without SDA uppder and dogbone mounts. EVER
Old 10-13-2007, 01:07 AM   #17
tarsun
hey well the SDA's are looken pretty good so far...
Old 10-13-2007, 10:15 PM   #18
plastic torpedo
2000 SL2
1994 SC2
yeah I love driving the car! It seems like it almost sounds different now, more throaty. One thing I definitely noticed is I had to re-learn driving on the freeway a little. Before with the stock mounts it took about a second from the time you gave it gas till the speedo starts climbing. Now as soon as I touch the gas it immediately begins to accelerate, and immediately decelerates when I let off the gas. So it takes a little time getting used to, I got distracted and accidentally went up to 75 mph tweaking my radio without even noticing it.
Old 10-14-2007, 12:48 AM   #19
Keeter
Keeter is on a distinguished road
Keeter's Avatar
1999 SL1
So, to do all the mounts and all the inserts what was the damage to your guys wallet? I've been interested in doing the engine mounts but have heard mixed reviews. Like there is a lot more vibration in the cab. Is that true?
That's my opinion,
Keeter
Keeter is offline   Reply With Quote
Old 10-14-2007, 01:55 AM   #20
plastic torpedo
2000 SL2
1994 SC2
vibration is increased, rattling is decreased. it's hard to describe. it's not annoying vibration. the damage for all 3 mounts would be around $150-$200 depending whether you get an insert or the whole top engine mount from SDA. i'd pay it again if i had to
SDA TAM mounts Red Sc2 S-Series Mods 22 04-06-2008 01:39 PM
Are polyurethane dogbone inserts a good idea? orneryhermit S-Series Tech 19 01-12-2008 04:18 PM
Polyurethane Dogbone Inserts Phonespider S-Series Mods 7 06-05-2006 01:04 AM
Mounts - SDA vs Prothane. Red97sc2 S-Series Tech 0 03-12-2006 03:46 AM
SDA Mounts getz999 Mods and Performance 1 10-01-2005 11:19 PM
