![]() Join Date: Jun 2014
1998 SW2
2000 SC2
Quick question, can a single cam engine be replaced with a twin cam engine without changing the PCM, I just spun a bearing in the bottom end in a single cam sc1, and know where there is a good twin cam motor... or do I have to switch heads over?
If you never go above about 75% throttle it'll be fine, otherwise the SOHC PCM's idea of full throttle fueling will go lean on the DOHC and burn up valves.
Depending on year swapping the PCM is a 'bolt-in' affair and unless prices have changed they're pretty cheap (under $70). |
1998 SW2
2000 SC2
ok thanks, I can see if I can also find a pcm for the twin cam motor as well too
Easier to Swap engine, or swap tranny? | Saturn #4 | S-Series General | 6 | 03-21-2016 09:44 AM |
Engine cradle swap; tranny swap | MikeNW | S-Series General | 6 | 03-11-2015 01:04 AM |
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed | msmay0 | S-Series Tech | 5 | 06-10-2012 05:01 PM |
engine swap ? 99 sl2 swap in 98sl2 | jiffypop | S-Series Tech | 1 | 12-11-2010 11:14 AM |
Engine Swap or trannie swap | SL-2er | Miscellaneous Tech | 1 | 04-28-2003 05:00 PM |
