Old 01-03-2018, 05:35 PM   #61
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
Default Re: 96 SC2 bringing it back to life (slowly)
Originally Posted by OldNuc View Post
WIX fuel filter and WIX 51516XP oil filter.
Thanks, I have WIX filters on order and an air filter.
I also ordered a mobile one oil filter for the startup procedure.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 01-03-2018, 08:45 PM   #62
If you missed this oil prime procedure this insures you start with oil on all bearings.
To prime the oil system on a Saturn engine after a complete overhaul, head replacement, timing chain replacement, re-ring, or long term storage perform the following steps.
-Fill crankcase with 4 1/2 quarts of fresh new 5w-30 oil if this is the initial fill following a rebuild otherwise use 4 quarts of oil. Use a decent quality name brand oil.
-Fill a squirt pistol type oiler with the same oil.
-Squirt oil into the square port on the right side of the filter base do this several times until you can not get more oil to stay in it. This will take 4 to 6 ounces of oil.
-Fill the new oil filter a bit more than 1/2 full and screw it in place.
-Remove the PCM B fuse from the UHJB (under hood fuse box). This will prevent the fuel pump and injectors from operating while priming.
-Remove spark plugs.
-Place 1 squirt of 5w-30 oil in each cylinder.
-Turn key to crank and crank engine with the starter until the oil pressure light goes out. This may take several 20-30 second runs of the starter.
-Release key when the oil pressure light goes off.
-Turn key to crank and crank engine again until oil pressure light goes out. Repeat 2 times.
-Replace spark plugs.
-Replace PCM B fuse.
-Prime fuel system by turning key to on but not crank and wait until pump stops, turn key to off, wait 30 seconds. Repeat 2 times.
-Start engine.
After start.
-If engine running as expected continue to let it sit and idle while you inspect for leaks and other off normal behavior.
-Do not touch the gas!
-Allow to sit and idle until the fan cycles on and off twice.
-Shutdown engine and allow a 30 minute oil drain down time
-Replace the oil and oil filter with a WIX 51516XP or Mobil-1 M1-209 (do not substitute) filter and a name brand high quality synthetic oil, or high quality name brand synthetic blend oil.
-Drive car conservatively, no steady RPM operation and hold max top gear RPM to < ~3000 RPM
-Closely monitor oil level by parking in the exact same spot and checking level after a 6 hour minimum drain down time. Maintain oil level at the Full mark or up to the lower edge of the "U" in full.
-Once it has been established that oil consumption is zero change oil and filter.
-At this point using a high end 100% PAO synthetic oil is the best option. Amsoil 5w-30 Signature Series or Amsoil
Series 3000 SAE 5W-30 Synthetic Heavy Duty Diesel Oil is recommended along with the WIX 51516XP filter. Do not run these filters more than 7500 miles but oil change can be done by oil sample results and no more than 700 operating hours. Buy an hour meter and hook it up.
Old 01-03-2018, 10:19 PM   #63
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
....And don't forget the O rings on the block before you install the timing cover!!!!!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-05-2018, 01:33 PM   #64
Mark_b
@OldNuc Thanks for posting that I plan on using it.
@waies191 wen we took timing cover off I showed them to my son and told him how important they were. I hope to learn lessons from your post and others.
I saw where super clean would help clean up the block and the head. We tested it on the head it was 30 degrees outside so we did not spend that much time on it yet. But it worked well. I look forward to using it on the block and the head again.
Before and after (I just sprayed it on let it sit pressured washed it off)
We got some parts in
I ordered a Lisle 36050 Valve Keeper Remover and Installer Kit. This should make putting the valve keepers much simpler.
Old 01-05-2018, 04:47 PM   #65
The fun part, clening... Be sure to flush out and blow out all the oil galleries. You really fo not left over cleaner or water in there. Those tors bit plugs will come out so all the gunk is ejected. To reuse the aluminum sealing washer just LIGHTLY rub both sides on a new sheet of 220 flint or garnet paper, no emery or aluminum oxide etc. Be sure to clean them off carefully. They do not have to be perfectly cleaned up, just enough to get a new surface to seal on. They torque to 20ft-lb. No sealer etc but a finger wipe of oil on the threads helps.
Old 01-07-2018, 10:15 AM   #66
Mark_b
We have a setback I went to Columbia SC to get my timing cover and some other parts.
We spent a fair amount of time cleaning it up. We finished cleaning it up yesterday and we very happy how it turned out. Then I noticed it has a big issue the part that holds the idler pulley is broken off.
My old cover has the top right bolt ear broken ˝ off. I wonder if I could cut the bolt ear off this one and weld it on the old cover?
Issue highlighted in yellow.
My son cleaned up all the valves and more parts came in the mail including valve lapping tool.
Old 01-07-2018, 10:24 AM   #67
Waiex191
Waiex191's Avatar
Bummer. Is that part steel? Maybe you can drill a couple small holes in the back, drive it out, and seal the holes with RTV. I'd be worried about the welding. That part needs to be pretty flat for sealing.
Edit: from my pics I see it is aluminum and part of the casting. Do you have a buddy who could machine you up a new one and then weld it in?
Bryan Cotton
Old 01-07-2018, 10:51 AM   #68
The idler pulley boss is aluminum and this is not repairable with anything unless you can find a real certified TIG welder and have access to a rather complete machine shop to finish the job. The ear could be tig welded back in place and finished with a hand file IF you are real careful. Easy - cheap way is find a new cover that has a good smooth oil pump cavity. 92-98 all swap. Check http://car-part.com/index.htm and local pick and pull.
Idler pulley boss breaks off when mounting bolt is repeatedly torqued to the over zealous OEM spec or the tensioner or idler pulley bearing locks up. That 20ft-lb is excessive when 15ft-lb will be just fine.
Old 01-07-2018, 11:28 AM   #69
Mark_b
Here it is the old one that had the ear broken off. They were trying to get the cover off without taking the middle bolt that you can’t see off.
I have a Mig welder with a spool gun. I know Tig would be the best but I might give it a try what do I have to lose.
I would try to weld the ear on and file it clean.
Is it the 98 cover that oils the chain?
Car-parts is an option I will call on Monday. Ebay wants $100 for one no way.
Old 01-07-2018, 11:49 AM   #70
Mark_b
One small thing in the valve cover cleanup happened. I did not know the part circled in red was plastic. I hit it with the pressure washer and a piece broke off.
It cleaned up very nicely.
Old 01-07-2018, 12:04 PM   #71
That is not good. It is remotely possible that you will not end up sucking oil into the engine through the PCV but using the single hole no moving part PCV is recommended. There is no easy way to replace that duct either. The baffle bottom it is mounted into is non removable and replaceable. Those are drive rivets and are removed by drilling and then you have to find and actually remove a intact duct and replace it into that baffle. The baffle is sealed to the oil fill hole boss on the inside as well.
Old 01-08-2018, 04:53 PM   #72
'98 for sure has it, '97 most likely does, and '96 probably does not
http://www.saturnfans.com/forums/sho...170045&page=19
OldNuc's research shows the hole as showing up in '97 but may have shown in in the late '96 production run as one member notes (as is the case with a lot of things Saturn, there is not a definitive cut off date)
http://www.saturnfans.com/forums/sho...d.php?t=127941
Old 01-08-2018, 05:11 PM   #73
Mark_b
Great thanks for the links.
Old 01-09-2018, 06:28 PM   #74
Mark_b
I made some progress today. It warmed up today so I welded the timing cover. I just made an aluminum Big Green Egg grill stand so I have done a fair amount of Mig aluminum welding.
The top is welded the bottom is before welding.
We got the rod caps cleaned up
I got the plastic valve cover part out of the old cover.
Now time to drill out the rivets
My 96 cover has the chain oilier. Now it needs cleaned up.
Old 01-09-2018, 09:10 PM   #75
Cut a slot in them, heat up cover with a heat gun and twist them out as they have 2 or 3 coarse threads on them. They are drive screws. Replace with fine thread blunt point metal screws into a tapped hole so as to not crack the aluminum. The baffle plate is RTV sealed to the chamber. Put the screws into oil free holes dry and the aluminum will oxidize and lock them forever. The weld repair should work.
Old 01-09-2018, 09:23 PM   #76
Mark_b
That sounds like a good plan. Thanks for the advice
Old 01-09-2018, 09:58 PM   #77
Waiex191
Waiex191's Avatar
Nicely done! Those engine guts look different than my '99. Did you mean cam caps?
Bryan Cotton
Old 01-09-2018, 10:11 PM   #78
Mark_b
Thanks. I was happy with it. I got good penetration. I cut off a different bolt ear and welded it back on as a test. That went well so I did the real thing.
Good eye yes those are cam caps.
Old 01-11-2018, 11:16 AM   #79
Mark_b
Just a little more cleanup on the block and it will be ready.
My son school break is over so the project will slow down again.
Old 01-14-2018, 12:55 PM   #80
Mark_b
We ran the ridge reamer it had very little ridge.
The cylinders have been honed and the gasket surface was cleaned.
One step closer.
2004 Saturn Ion 2 QC 2.2 manual - revs slowly, returns slowly to idle chetterhead Ion Tech 14 09-22-2012 10:43 PM
Bringing the old gal back to life Hjoken S-Series Tech 21 02-24-2012 11:45 AM
Could Magnas Unique Business Model Lure Penske into Bringing the Astra Back to Lif wifeofcore General Saturn Discussion 14 06-17-2009 11:46 PM
Bringing 94 SL1 back to life - been sitting for 3 1/2 years Spazie S-Series General 19 01-02-2008 01:19 PM
bringing a $400 SC2 back to life geartooth94 S-Series Tech 9 01-12-2005 08:31 AM
