Old 04-01-2016, 08:27 AM   #21
Warren72955
Warren72955 is on a distinguished road
Default Re: 2004 Ion trunk leak
Hello; I wanted to update everyone on my 2006 Ion Quad trunk leak, of which this site has been useful in partially fixing. I first noticed some staining of my headliner and my car has the sunroof. I removed the headliner and was able to clean the stains simply using some upholstery cleaner and surprisingly all of the stain is gone. (The glued on wires to the headliner were a pain; I have now glued them to the roof like they should have been at the factory). On the 4 sunroof drain tubes part of the leakage is due to a short connection on joints with no sealant of any kind; all joints are now sealed with silicone caulk. That was also a problem on the 2 drain joints in the trunk before it goes out the fender on each side. I have also enlarged the drain holes on the rubber fender fittings on all 4 corners so debris will not back up. My existing vent on the passenger side rear did not have any problems so have not done anything to it. After all this was done I was still having some leakage into the trunk especially on the driver side fender. I noticed some water inside the trunk lid every time I opened it so I caulked the spoiler attachment nuts (4); still getting leakage. The final item I found was leakage of the trunk plastic rear panel which is attached to the metal trunk with some press-on tabs on top (poor seals) and a few Torx screws. (See pictures) I have now silicone caulked all holes for the press on tabs and any other holes into the metal trunk. A word of caution: the license plate light will need to be unscrewed and it is necessary to temporarily tape back in place so you can attach it once the plastic rear panel is put back on. Now it appears I have finally fixed all leaks.
Warren
Add to Warren72955's Reputation
Rate the quality of this post and help Warren72955 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Warren72955 is offline   Reply With Quote
Old 04-01-2016, 11:11 PM   #22
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
Thanks! I'll check those holes. it totally makes sense.
fixed/replaced so far: side mirror, window trims x4, trunk floor, radiator bushing, alternator, starter, LCA x2, sway bar bushings x2, end links x2, timing chain tensioner, O2 sensor.
Add to jacek_p's Reputation
Rate the quality of this post and help jacek_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jacek_p is offline   Reply With Quote
Old 04-02-2016, 05:54 PM   #23
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
I looked again today and removed water on both sides (it has been raining hard every day) and noticed a big round hole on the left going to the under bumper space. this is the area corresponding to the vent on the right.
see the center of a close up. Is it supposed to be open and not plugged up?
Old 04-03-2016, 09:18 AM   #24
2006 ion2
2007 ION-2 Sedan
That looks like where the sunroof drain goes
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 04-03-2016, 01:12 PM   #25
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
but i have no sunroof. should i plug it up?
Old 04-03-2016, 08:13 PM   #26
2006 ion2
2007 ION-2 Sedan
Yes, you should.
2007 Saturn Ion 2
Old 04-03-2016, 10:14 PM   #27
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
Yes, you should.
you are right. there was a similar 3/4 hole on the right, but taped over. either tape came off on the left or was never put in the factory. so, i taped it over.
i also cleaned and sealed the vent on the right and will see what happens next before taking apart the plastic cover of the trunk.
Old 04-11-2016, 03:08 PM   #28
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
Warren
thank you Warren one more time for this write up. inspired by this, i took the plastic trunk "skin" apart. it turned out one of the plastic clips was missing, leaving a gaping hole on the top. 2nd, sealing foam tape deteriorated and there was a poorly sealed hole in the rear. i tapes those 2 holes and hope the tape will stick. otherwise, i caulked the other holes that had plastic clips or screws. see the pictures.
now, IMHO, the who design is silly. the plastic "skin" has no function whatsoever, and the top attachment to the real metal trunk lid creates a space where water seats and creates corrosion. this is the only space in the entire (southern) car that had some corrosion. this should be all metal just like the hood is.
Old 04-30-2016, 04:08 PM   #29
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
update:
it rained hard a couple of days ago and i just checked the trunk. there was a huge improvement, but small amounts of water was present under the vent (that was carefully sealed with sealant). not sure what else to do, i'll probably live with that.
Old 05-01-2016, 09:59 AM   #30
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
Originally Posted by jacek_p View Post
update:
It could be just the design of the vent. I get water as well. Not too concerned about it though.
Add to chilipepper1327's Reputation
Rate the quality of this post and help chilipepper1327 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chilipepper1327 is offline   Reply With Quote
Old 05-02-2016, 03:07 PM   #31
Warren72955
Well, we have had lots of rain in Alabama this Spring and still no leak in the trunk on the driver side and my vent on the passenger side is also ok. So I guess my problem is solved so everyone needs to remove their plastic trunk part and caulk all the holes.
Old 05-03-2016, 01:06 AM   #32
awelch
awelch is on a distinguished road
awelch's Avatar
1992 SL2
2007 ION-3 Sedan
did you do it from inside the trunk or from outside. if from outside, how did you get there. did you remove the rear bumper first?
Sorry for the late reply. I have not been on Saturn fans as much. Anyway, as the other person suggested, yes I did all the work from the trunk without removing the bumper. It requires patient manipulation to get the vent out through the rectangular hole and clean everything up nicely.
Add to awelch's Reputation
Rate the quality of this post and help awelch reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
awelch is offline   Reply With Quote
Old 05-05-2016, 10:56 AM   #33
chilipepper1327
You're right, you don't need to remove the bumper at all and it really isn't that difficult. I did mine and I still get a little water. Bad design...
Old 11-22-2017, 03:32 PM   #34
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
This is my conclusion as well. Keeps leaking both left and right corners even after extensive use of caulk everywhere. I'm a bit concerned as some mold showed up.
Old 11-22-2017, 03:47 PM   #35
chilipepper1327
For mold, there has to be some kind of organic material. I wouldn't worry about it. Just keep it dry and you should be ok.
Old 11-24-2017, 09:36 AM   #36
csc67
csc67 is on a distinguished road
I had a trunk leak on both sides in my 2007 Saturn Ion 3 and did a lot of reading about vents / sunroof concerns
When I removed the side carpet in the trunk, I discovered that the rubber drain hoses had become discounted for the 90 elbow. I put them together and put some Gorilla Glue tape on them to avoid them from coming apart again and no leaks for three months
Check this first
Good luck
Add to csc67's Reputation
Rate the quality of this post and help csc67 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
csc67 is offline   Reply With Quote
Old 12-09-2017, 09:35 PM   #37
mitche
mitche is a jewel in the roughmitche is a jewel in the roughmitche is a jewel in the rough
mitche's Avatar
2006 ION-3 Sedan
Another place to check, open trunk, look at channel next to trunk seal about midway between back glass and tail light, you will see where two metal body panels join. The factory sealant gets dry and cracks allowing water in. Chip out old sealant, reseal. I also sprayed rustoleum flex seal on everything back there. Remove tail light you will see the other factory caulking for body joints.
Rustoleum drips like crazy so use plenty of plastic or whatever to protect from drips.
I don't speed much anymore but I don't slow down for turns much either to keep the fun factor.
Add to mitche's Reputation
Rate the quality of this post and help mitche reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mitche is offline   Reply With Quote
Old 12-20-2017, 02:20 PM   #38
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
Thanks, I'll check for that when son comes back home. Would caulking work for that?
Old 01-14-2018, 09:28 PM   #39
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
this what we did this weekend. my son hid in the trunk with a flashlights and I liberally sprayed the car with water (on a warmed day). he could see no leaks inside, yet there were fair amounts of water in the trunk before the test. unless the trunk accumulates water during driving, we are at loss where it comes from.
I did not see any joints that needed caulking, but forgot to remove the taillights to check.
Old 01-22-2018, 11:32 PM   #40
kaylan87
kaylan87 is on a distinguished road
Bummer dude.
My 06 Ion seems to have had a leak as well. And Im going to try the "hide in trunk while someone sprays my car with a hose" test as well. If anyways, Im just going to try caulking some areas inside the trunk
Check out this video.
https://www.youtube.com/watch?v=2IbG3PH8Duw
Add to kaylan87's Reputation
Rate the quality of this post and help kaylan87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kaylan87 is offline   Reply With Quote
98 SC1 Trunk Leak mattelderca S-Series General 16 05-03-2014 10:45 AM
Trunk leak fix! MJD112379 Aura General 13 07-24-2008 12:58 PM
Trunk leak on an '02 Alex_SC2 S-Series General 3 03-21-2008 09:00 AM
Trunk leak patcal S-Series General 3 11-01-2005 08:40 PM
Trunk vent leak Cheebs Ion General 2 08-23-2005 07:04 PM
