Old 03-12-2021, 06:16 PM   #41
V3DT
V3DT will become famous soon enoughV3DT will become famous soon enough
Default Re: I went to check on a issue with my parking brake but found something way worse..
Painted & sealed it up, I would like to do more but I need it back together so I can get to work. So it'll have to wait or I should just start looking for another car that isn't a rolling fossil.
V3DT is offline   Reply With Quote
Old 03-12-2021, 10:55 PM   #42
V3DT
Old 03-14-2021, 12:55 PM   #43
V3DT
Does anyone know the torque specs for the rear seat, seat belts?
I'm having a hard time finding what they should be for some reason.
Old 03-14-2021, 01:30 PM   #44
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
I can check the factory service manual when I get home from work. Iím guessing itís probably equal to 4-5 ugga-duggas
97 SL2, auto, 123K miles
Old 03-14-2021, 02:53 PM   #45
V3DT
The driver's side took like 3 minutes of ugga-duggas to get off, while the passenger side was a lot easier & the center ones just zipped off in a second.
From what I can tell is someone has been there before & over torqued the driver's side to the point it dug deep into the plastic for the bench seat & cracked it.
Old 03-14-2021, 06:24 PM   #46
V3DT
Just went with what felt right. If someone posts the torque specs or I find them somewhere & I feel it needs adjusted, the seat cushion is easy to remove at least.
Old 03-14-2021, 10:27 PM   #47
Zeebins
Zeebins's Avatar
37 ft/lbs for the rear seat bolt to floor pan. Almost all of the seatbelt related bolts are 37 ft/lbs actually.
Only two that are different is the front seat buckles requiring 55 ft/lbs, and the rear seat belts to shelf panel is 89 in/lbs for the coupes only.
Old 03-14-2021, 11:29 PM   #48
V3DT
Thank you. I had put them at 27ft/lb, I'll have to tighten them a bit more. I'll likely have to replace the plastic seat support though because it was cracking more while tightening the driver's side bolt down. By 37ft/lb I bet it'll crack completely through.
^ That is at 27ft/lb, the damage to the plastic was already there. Someone in the past must of really torqued it down too tight.
I wonder what Pullapart would charge for that piece?
How to check the parking brake switch? flyhop S-Series Tech 5 07-10-2017 08:14 AM
Parking Brake Issue trottida S-Series General 4 08-22-2016 12:56 PM
Parking brake issue? golftango Aura General 4 05-29-2010 01:24 AM
Parking brake/rear caliper issue derf S-Series Tech 17 04-02-2009 11:51 PM
'96 SC1 parking brake issue chadrules S-Series General 9 03-09-2009 09:06 PM
