Old 10-01-2013, 11:14 AM   #1
dkwhite
dkwhite is on a distinguished road
Default Trouble codes P0341 and P0606. Do I have a bad PCM?
I have a 2001 Saturn with a 1.9L engine with 180k miles.
The car seems to run fine until it is under a load, Like going up a hill or holding the brake while in drive and giving it a little gas. The car will sputter and have trouble building any RPM’s. This also seems to make the Service Engine Soon light come (after it has been cleared) and give a P0341 code.
So I have been trying the things suggested from this forum for clearing the P0341 code.
1. New plugs and wires
2. New coil packs
3. Cleaning the Ignition Module and the transmission where it bolts too.
4. Tested the power and ground from the wiring harness that plugs in to the Ignition Module. Inspected for corroded connection
The next thing is to replace the Ignition Module all together. Price over $100 dollars
Problem is that twice I have gotten this P0606 code while testing the new parts.
So finally my question:
Dose the P0606 mean I have a bad PCM?
I don’t want to keep throwing money at this car just to find out the part to fix it is worth more than the car itself .
Add to dkwhite's Reputation
Rate the quality of this post and help dkwhite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dkwhite is offline   Reply With Quote
Old 10-01-2013, 11:58 AM   #2
Default Re: Trouble codes P0341 and P0606. Do I have a bad PCM?
Go to a junk yard and buy the complete module, coils and ICM, will be 30 to 40 for all of it. After market may be overpriced junk and used OEM is much cheaper.
Old 10-01-2013, 12:32 PM   #3
Yours may be the first here to spit out P0606; PCM internal performance.......This DTC will set when the PCM determines that its microprocessor has failed.
Rather than ponder why this error code popped up, your engine runs and this means the pcm is working. False errors are part of electronics troubleshooting and this error code may go away on its own.
Any mods on this engine? What's battery/alternator voltage?
Old 10-01-2013, 06:40 PM   #4
dkwhite
Thanks for the replay guys.
Good Ideal OldNuc I will start calling around to junk yards tomorrow.
“False errors are part of electronics troubleshooting and this error code may go away on its own.”
Thanks fdryre, that’s good to know.
Sorry about that I am kinda new to Trouble code troubleshooting.
I am pretty sure the engine is stock.
Battery voltage: 12.56, alternator voltage 14.62
Well I will try to find the parts at the junk yard and continue on. (wish me Luck)
And thanks again for your help.
Old 10-01-2013, 06:51 PM   #5
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Try to find a pull your own parts yard and you can probably get everything plus the PCM for $ 50 or less. Just comes down to whether they happen to have the correct PCM.
Did you check to see if you have the brass ECTS and what type plugs and wires did you use ?
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-05-2013, 03:38 PM   #6
dkwhite
Just wanted say thanks guys, car is running great.(no trouble codes)
It was the ignition module,,, $40 bucks from the junkyard.
You guys saved me a bunch of money.
P0341 trouble code Sky King S-Series Tech 4 02-06-2012 03:57 PM
2003 LW300 Codes P0606 & P0102 Wagonfan L-Series Tech 5 08-14-2010 02:56 AM
2002 LW300 lost power at full throttle. Codes P0102, P0606, P1510, P1519 ejs L-Series Tech 11 03-11-2009 05:38 PM
codes P1510 and P0606 stokesdead L-Series Tech 11 12-02-2008 02:14 PM
Trouble Code P0341... Need help please striker1584 S-Series Tech 1 09-09-2008 03:51 PM
