Old 03-01-2010, 10:15 PM   #1
turbogtu
turbogtu is on a distinguished road
Default tgp ecm to run turbo on 1.9l saturn
Just searching the mods section and didn't see anyone running the turbo grand prix code. It uses a 7x crank trigger much like the saturn 1.9. You can use either the 88-94 grand prix 727 ecms or the beretta type 730 ecm. Just flash the eprom/eeprom with the moded tgp code. Changing values from 6 cylinder to 4, and remaping the fueling. THeres plenty of support for it. Like wideband and live datastream recording. Flash on the fly from moats.net. THough it will only work for the 5spd.
Add to turbogtu's Reputation
Rate the quality of this post and help turbogtu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbogtu is offline   Reply With Quote
Old 03-01-2010, 10:22 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: tgp ecm to run turbo on 1.9l saturn
Are you saying this is something you've done?
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 03-01-2010, 10:50 PM   #3
turbogtu
Nope, haven't done it yet. Just throwing it out there as an option vs megasquirt or the like. I could see using the caviler 2.2 isuzu coil pack, modual to control spark.
Old 03-02-2010, 12:19 AM   #4
Leafy
Leafy is on a distinguished road
Leafy's Avatar
I dont see this working unless you're extremely retardely lucky.
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 03-02-2010, 12:18 PM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
While I'm a bit skeptical, it does have a chance if someone knows what they're doing.
Old 03-02-2010, 12:21 PM   #6
Leafy
Leafy's Avatar
it has a chance if they use the same pcm, if the pcm is different then you just have to pray that the OS you install on the chip will be able to figure out what the titty **** is going on and get all the inputs and outputs right. oh and dont forget you'll have to fake a cam sensor by using that output from the saturn icm or actually add a cam sensor.
WPI class of '12 ME
Old 03-03-2010, 12:42 AM   #7
turbogtu
The tgp code, ecm doesn't need a cam sensor since its not a a sequential injection ecm. Just needs a ICM from a caviler (were omiting the saturn ICM). Run it off the stock Satun crank trigger. The code just needs to be able to control the spark advance, and this ICM will "speak" its languag..ie pwm. The TGP code will work on the '730, '727, '749 ecm. These are found on 88-92 gm cars and rare syclone/typhon. I'd have to check my documentation but I think the sy/ty and grand am turbo code will also work on the cavi icm. The sy/ty has some 3bar codes out there or using the hacked $59 3bar code. TGP still uses the 2bar map sensor.
Old 03-03-2010, 12:45 AM   #8
PurdueGuy
PurdueGuy's Avatar
1999 SC1
You should probably be talking to people on sixthsphere.com about this stuff. Most of the people on this site are mainly interested in getting the best fuel economy they can. Sixthsphere is where most of the turbo guys are at.
Old 03-03-2010, 12:49 AM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Shure as heck isnt plug and play. A whole lot of rewiring would have to be done. This is a 1993 Grand Prix 727 PCM.
And here is what a 91-95 PCM looks like
1996-1999:
2000-2002:
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 03-04-2010, 09:29 PM   #10
turbogtu
Ok, I see. Yup, nothing is plug and play, but having both wiring diagrams will help. Theres a site that list all the I/O of said ECMs. You'd have to use the Cavi or Beretta memcal though from a 4 banger since it has the spark "limp" mode tables in there.
Old 03-04-2010, 09:36 PM   #11
Leafy
Leafy's Avatar
you might also be able to use the J-body pcm since those are also 7x crank triggers (and we wish they were 54x so that we could use LSJ and 2.4 bottom ends).
WPI class of '12 ME
turbo saturn =D ohthathurts S-Series Mods 60 12-29-2009 03:59 PM
saturn turbo mpg bobyjones S-Series Mods 12 07-13-2009 11:27 PM
FS: Turbo Saturn... Rob1998SL2 Classifieds 3 05-07-2006 10:07 PM
Vid Of My Turbo Saturn SIYAM S-Series Mods 12 12-01-2004 10:17 PM
New Saturn Turbo kit SpeedSW2K1 Mods and Performance 10 09-07-2001 05:50 PM
