Old 05-21-2019, 11:13 PM   #1
SomeTech
SomeTech is on a distinguished road
Default 3800 series 2 swap
Me and a buddy are tossing up the idea of stuffing GM's 3.8L v6 into his S-series, to get a platform for racing/upgrading going. He's got the inline 4 in it currently, and I believe it's a 96. It's the 91-2001 model I think, from what I saw on here. Was just wondering if it was compatible, since someone put an LS4 in an L series. If it is, what should we expect to buy, do or remove?
SomeTech is offline   Reply With Quote
Old 05-22-2019, 06:58 AM   #2
Default Re: 3800 series 2 swap
The hardcore S Series hot rodders are over here:
https://sixthsphere.com
Good luck! I have no idea how to answer your questions but I think not a lot is compatible.
Old 05-24-2019, 01:49 PM   #3
amazinghl
Let me google it for you.
https://www.google.com/search?biw=12...WoYl3y554PXxM:
00 Insight 72mpg
amazinghl is offline   Reply With Quote
Old 05-25-2019, 09:55 AM   #4
Once you custom fab up the mounts & connections it bolts right in, no issue's.
Old 06-04-2019, 04:24 PM   #5
Saturn Night
Stuffing the 3800 Series-II will require some fabrication work and the matching transmission. Use a 1997 Grand Prix GTP tramnsmission, as that was a lone year of the 4T65E Heavy Duty 4-speed automatic.
You will need to cross-reference the wiring diagrams, as the harness from the donor engine/transmission will need to be spliced into the stock Saturn wiring, and you will need to use the PCM from the Grand Prix engine/transmission.
also, plan on measuring the lifespan of your inner, left side tie rod with a stopwatch, as the exhaust manifold will be very close to the rack n pinion.
It can be done.
GM 3800 V6 in a Vue? What do ya think Vue&SL1 Vue General 19 12-16-2007 12:06 AM
Help: Should I Buy 99 SW2 43K $3800?! futubutu S-Series General 19 06-28-2007 09:24 AM
RPMs wont go over 3800 in any gear!?! IZFresh69 S-Series Tech 6 04-14-2007 06:06 PM
1994 Saturn SL2, only 77,000 miles, $3800 dhdh Classifieds 2 06-26-2006 08:44 PM
3800 RalliArt16 S-Series Mods 53 04-20-2006 09:56 PM
