Old 05-19-2019, 05:59 AM   #81
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Re: Oil Filter Location
Im surprised no one has tried a right angle oil filter adapter....
You could then use a ginormous Wix 51515 / Fram 8a filter...
Or an even larger Wix 51773...
https://www.summitracing.com/parts/f...-a50/overview/
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 05-19-2019, 08:44 AM   #82
onlinebiker
I don't do acrobatics.
I put the car up on the lift, place the 25 gallon drain tank ) adjustable funnel height) underneath - pull the pan plug - then the filter.
I give it 20 minutes or so. I'm not in a hurry.
And it gives me time bro give the underside a good looking over...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 05-19-2019, 11:59 AM   #83
Signmaster
If I ever build a place, it will have at least one lift. But for now crawling under is the way it goes.
Old 05-20-2019, 12:44 PM   #84
Same here.
This has been on my "when I have an extra $2,000 laying around" shopping list for a while (pretty far down ). Would come in handy several times a year but not quite worth buying, yet. Gotta wait for the youngest to graduate college
https://www.quickjack.com/car-lift-s...-car-lift.html
Old 05-22-2019, 04:08 PM   #85
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
dummo is online now   Reply With Quote
Old 05-23-2019, 12:05 PM   #86
cpy911
cpy911 has a spectacular aura aboutcpy911 has a spectacular aura aboutcpy911 has a spectacular aura about
1996 SC2
On my to buy list:
https://www.harborfreight.com/6000-l...ift-91315.html
Wait for a 25% coupon and get it for $1200!
Add to cpy911's Reputation
Rate the quality of this post and help cpy911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cpy911 is offline   Reply With Quote
Old 05-23-2019, 01:16 PM   #87
No way am I getting under that!
Add to Waiex191's Reputation
Old 05-23-2019, 03:27 PM   #88
454cid
454cid is on a distinguished road
I agree, that doesn't look safe, at all.
Add to 454cid's Reputation
Old 05-23-2019, 04:26 PM   #89
cpy911
1996 SC2
It is totally safe...if used correctly and per the instructions. Saw a guy try to knock a jeep over on it...it is extremely stable. No issues with it. Do your research...it is fine.
Old 05-23-2019, 04:50 PM   #90
cpy911
1996 SC2
https://www.youtube.com/watch?v=MxpaJj4H4cI
Oil Filter Location - WHAT?? Pitcher S-Series General 29 09-18-2009 11:44 PM
99 sc2 oil filter location? Salsa88 S-Series Tech 5 01-17-2008 06:25 PM
oil filter location ErichPryde Vue Tech 5 11-14-2007 06:27 PM
Oil Filter Location? markcp S-Series Tech 2 05-13-2006 11:40 AM
3.5L oil filter location? Bullet Vue Tech 2 06-26-2005 11:24 AM
