Old 10-11-2018, 11:37 AM   #1
Psycho-Ions2
Psycho-Ions2 is on a distinguished road
2007 ION-2 Sedan
2005 ION-3 Quad Coupe
Default 07 2.2L Ecotec Ion 2 Crankcase swap
So my 2.2L 2007 Ion 2, decided to throw a rod through the crankcase last night, halfway on my commute home from work. I found a possible donor 2.2L long block engine for less than $400 it has 10k miles on it, but it's from a wrecked 2002 Vue. What I want to know is, would it line up with the head sleeves/block on my 07, is there any variance between the years, as far as block internals that it won't line up right? I don't know any local shops, or people that specialize in Ecotec's or can answer this.
Thanks in advance.
Add to Psycho-Ions2's Reputation
Rate the quality of this post and help Psycho-Ions2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Psycho-Ions2 is offline   Reply With Quote
Old 10-11-2018, 10:23 PM   #2
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Re: 07 2.2L Ecotec Ion 2 Crankcase swap
There are a few differences between the first generation L61 (the 2002 long block) and the second generation L61 (the 2007 in your car)...
1. The crank sensor and ring on the crank are different. You could swap your 07 crank in the 02 block perhaps but given that you ejected a rod I imagine your crank is damaged.
2. The heads are different, the 07 has a cam position sensor whereas the 02 doesn’t. The 02 relies on the compression sense ignition to generate a cam signal to operate the sequential fuel injection...
While you *could* swap the 07 crank and head into the 02 block, I imagine you’d be better off finding an 07-08 2.2
If you could find a 2.4 (LE5) cheap enough, you could stick the L61 head on it and have a 2.4, minus the VVT, as I think the crank wheels are the same
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 11-24-2018, 06:15 PM   #3
Psycho-Ions2
2007 ION-2 Sedan
Thanks for that bit of info, I'm glad I read this before I dropped $200 on this '02 L61 I saw locally. I'll keep looking, though after I find another car for the interim time, gotta have something for winter to get to work, public transit is annoying lol.
05 ion ecotec swap with 07 chevy ecotec spenser4 Ion Tech 7 03-31-2017 12:54 AM
05 2.2 ecotec swap emsvitil Vue Tech 2 02-15-2011 11:14 PM
LE5 Ecotec Swap saturn00b Vue Mods 5 03-13-2008 10:38 PM
Ecotec swap so0dz S-Series Tech 37 11-12-2007 11:01 AM
2.2 ecotec swap quiksc2 S-Series Mods 24 04-04-2007 11:38 PM
