Old 04-16-2018, 04:59 PM   #1
bigtoque
bigtoque is on a distinguished road
Default 2001 SL2: What is this little hose?
I've got a 2001 SL2, and looking under the hood today I noticed a little hose/connector that appeared to connect some part of the alternator to another little hard plastic hose. I'm not sure what I'm looking at and haven't had much luck on Google.
https://i.imgur.com/sNKwolB.jpg
Anyone know what I'm looking at?
Add to bigtoque's Reputation
Rate the quality of this post and help bigtoque reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigtoque is offline   Reply With Quote
Old 04-16-2018, 05:09 PM   #2
Macgyver
Default Re: 2001 SL2: What is this little hose?
It's the vacuum hose that runs from behind the throttle body plate to your air pump officially called the "Secondary Air injection System". It warms up your catalytic converter faster when the engine is cold to reduce emissions. I'm sure your check engine light has been on with the trouble code P0410 as well.
You can remove that rubber elbow and just connect the two hard plastic hoses using generic vacuum hose. I can't remember the size needed off the top of my head, but any auto parts store should have it.
Add to Macgyver's Reputation
Old 04-17-2018, 11:39 PM   #3
bigtoque
Thank you!
I actually had that error code a few weeks ago. I reset the error codes and was waiting for codes to return so I could see what was a new code and what might have been an old code. Driven about 400 miles since I reset it and nothing has come up yet.
I ended up watching a YouTube video about the issue and it looks like
this part isn’t working.
Old 04-18-2018, 09:14 AM   #4
BV22
2002 SC1
The solenoid switch allows vacuum to pass through to the diverter valve, which opens it, allowing air from the air pump into the exhaust manifold. With the vacuum source line broken, none of this will work. Fix the vacuum line first. The solenoid switch only opens while the air pump runs (about 60 seconds on a cold start). The switch can fail, but it is not a common failure.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 04-20-2018, 08:29 PM   #5
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
That’s what she said.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
2001 L300 Heater Core/Hose Leak aalegrete L-Series Tech 49 02-15-2015 08:10 PM
can I use smaller size deaeration hose in 2001 SL2 vikasevan S-Series Tech 4 01-28-2015 12:34 PM
2001 L300 Brake Booster Vacuum Hose ?? phatboy L-Series General 7 01-25-2015 05:33 PM
Power steering pump return hose - type of hose Upstate Saturn S-Series Tech 7 12-12-2014 12:17 AM
97 SL1Replacing short crimped hose from res to hose assy? Chris0381 S-Series General 1 05-28-2005 02:06 PM
