Old 07-13-2019, 10:23 PM   #41
Silverblu02SL2
Default Re: Is it possible to modify my 02 SL2 to open/ close windows w/o key in ignition?
Because the motor fries at 30A. The 30a fuse is toprotect the upstream source of power, you want to protect the motor from inadvertent stuck switch.
What does "because the motor fries at 30A" mean? Where did you get that from?
What amperage does the starter motor fry at? Should I put a fuse in series with it in case the ignition switch get stuck? Of course not!
The chance of a ignition switch getting stuck is probably the same as a window switch getting stuck. Thanks but I am not worried about it.
Add to Silverblu02SL2's Reputation
Rate the quality of this post and help Silverblu02SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Car window closer automatic close car windows Bozarth Ion General 6 04-29-2015 07:42 PM
Open seat zipper - how to close? usa4624 S-Series General 1 07-18-2013 05:03 AM
Sunroof will not open/close - motor sounds ok 1985 S-Series Tech 1 06-09-2011 10:23 AM
PCV Valve cycling open and close?? BasilCarey S-Series Tech 8 11-22-2009 01:16 AM
What tells the EGR to open or close? kornphlake S-Series Tech 15 08-15-2007 03:54 PM
