Old 05-16-2019, 10:48 PM   #1
silverslp
silverslp is on a distinguished road
2002 SC1
Default Multiple Misfire
Hello all. I recently replaced my plugs (NGK) and wires (AC Delco) as preventative maintenance in my 2002 Saturn SC. I have verified that the plugs are ran correctly. Now I am getting a misfire and p0300 code. I took off the 2nd coil pack (the right side) and noticed that there was a small copper strip broken off, so I got a new coil pack. No change in symptoms. When I have that coil pack removed completely, there is also no change. I am wondering if it is the ICM? Should I replace both coils at the same time?
The car was running excellent... this appears to have happened immediately after I installed the upper bolt on the 2nd coil pack that holds the retainer for the plug wires.
Thanks for the help in advance.
2002 Saturn SC1 - 175k Miles - Manual Trans.
2005 Saturn Ion 3 - 115k Miles - Auto Trans.
1998 Saturn SL2 - 185k Miles - Auto Trans.
Add to silverslp's Reputation
Rate the quality of this post and help silverslp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverslp is offline   Reply With Quote
Old 05-16-2019, 11:48 PM   #2
Default Re: Multiple Misfire
I am not familiar with those later coils that use a hold-down clamp for the plug wires. Can you post a picture showing the "broken copper strip"?
Add to billr's Reputation
Old 05-17-2019, 06:55 AM   #3
silverslp
2002 SC1
I believe it is the ground strap?
Update: I go out to start the car this morning and it runs super smooth. Wondering if the cylinders were flooded from that bad coil pack? I could definitely smell raw fuel last night.
Old 05-17-2019, 08:26 AM   #4
The brass strip you can see is a part of the RFI suppression system. If you changed out the entire module and the car runs now then most likely the ICM is what failed. It could also have been an incorrectly seated plug wire. Those plug wire hold down clips are of minimal value and they can be removed and the bolts replaced with the older short ones.
Old 05-18-2019, 12:10 PM   #5
silverslp
2002 SC1
Yesterday, everything was running great. Now today on my way home, I had another major misfire. The only thing I have replaced is the plugs (NGK) wires (ACDELCO) and the coil pack on the right side. Does this sound like the icm?
Old 05-18-2019, 12:21 PM   #6
Yes it does. Go to your local pick and pull and collect the entire module from a 96,97,98, or 99 Saturn, that is both coils, ICM, and the bolts. Aftermarket is just wat too expensive for what you get.
You did not install platinum plugs did you? They will cause that kind of problem.
Old 05-18-2019, 12:25 PM   #7
silverslp
2002 SC1
Thanks for the advice! The plus I installed are the recommended copper ones.
Old 05-18-2019, 03:04 PM   #8
silverslp
2002 SC1
Just wanted to give an update; I replaced the ICM, went for a drive and all is good. I just find it strange that both the right coil pack and the ICM would coincidently go bad at the same time I was doing plugs and wires. Thanks to all who contributed.
Old 05-18-2019, 05:23 PM   #9
The gen-3 ICM is know to cause that problem all too often. That is why I told you to go find an older one.
04-07 Vue - 3.5 Multiple Cylinder Misfire far2grumpy Vue Tech 8 04-19-2016 05:47 PM
ANOTHER multiple misfire CHALLENGE!! SOHC S-Series General 28 06-27-2013 06:53 PM
Random Multiple misfire tubaking182 S-Series Tech 6 06-02-2013 07:24 PM
3.5 Multiple Cylinder Misfire far2grumpy Vue Tech 5 12-01-2012 12:06 AM
Random Multiple Misfire Help icetea07 L-Series Tech 3 04-19-2012 01:05 PM
