Old 05-17-2019, 07:50 PM   #1
Chaz9496
Chaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the rough
2001 L-Series 2.2L Sedan
2003 L-Series 2.2L Sedan
Default 2.2 L200 Engine Swap.
I have a question about L Series engine swapping. will a 2001 swap out with a 2003 L200 2.2 ? I got a quote of $1075 for swapping engines from the 2003 to the '01. I can't do it here due to apartment garage regulations. It's got 198K on it and just started smoking this week. The oil was changed, by me anyway every 2 to 3K miles and was taken care of. I was just going to have the salvage yard come haul it away from the shop once they're complete, if they can be swapped. The techs weren't sure if they'll exchange or not. They would have look into it. From what I was told the computers make no difference on the same engine. They both have 4T40E transmissions. I was also told to check the PCV valve before doing anything. If they plug up it can mimic a worn engine. Thanks in advance.
Add to Chaz9496's Reputation
Rate the quality of this post and help Chaz9496 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chaz9496 is offline   Reply With Quote
Old 05-18-2019, 12:58 AM   #2
02 LW300
02 LW300 is just really nice02 LW300 is just really nice02 LW300 is just really nice02 LW300 is just really nice
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: 2.2 L200 Engine Swap.
I put a 2003 engine into my 2002 with no problems, I used the 2002 exhaust manifold because the car had an electric a.i.r. injection pump. The L61 engines are the same from 2000 to 2006 in GM cars. The thermostat housings and the manifolds have minor differences. Just use the manifolds from the car you are keeping and you will be fine.
Add to 02 LW300's Reputation
L200 engine swap JAMMANICA L-Series Tech 8 04-10-2017 01:30 AM
L200 2.2 Engine Swap chiliman10 L-Series Tech 2 03-24-2014 04:10 PM
Engine swap 2.2 ecotec (w EGR tab) L200 helpful notes Solion L-Series Tech 1 02-04-2013 01:47 AM
2001 L200 2.2 Ecotec engine swap ptabakaru L-Series Tech 0 03-22-2009 11:13 AM
L200 swap from ION '07 dcal456 L-Series Tech 1 04-30-2008 01:30 AM
