Old 05-17-2019, 06:12 PM   #1
Howiler215
Howiler215 is on a distinguished road
1992 SL1
Default 5 speed swap no spark
I swapped in a 5 speed into my 92 sl1 and now have no spark. I have good fuel pressure but no spark at all. Following the Haynes manual it led me to the ignition control module. I ordered a used ICM on eBay popped it on and the car fired right up. Battery is charged and reading 12.6V
I put the battery tray etc. back together to test drive it and same problem came back. Cranks over healthy but no spark. I replaced the crank sensor already even tho it ohmed 800. Also replaced coolant temp sensor twice and connector.
I checked all the fuses and wiring from the crank sensor to the icm and checked continuity from the icm to the pcm. I tried a different pcm and still no spark. Iím at the end of my rope, I went thru all the trouble of swapping to manual after I couldnít get my auto working and havenít even got to test drive it. The car ran great before pulling the transmission, although Iíve barely driven it I bought it with issues, and donít know any history on it.
Add to Howiler215's Reputation
Rate the quality of this post and help Howiler215 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Howiler215 is offline   Reply With Quote
Old 05-17-2019, 10:11 PM   #2
Default Re: 5 speed swap no spark
If the ICM is good then the problem is in the connectors, usually the one with the 6X signal. Did I direct you to the gen-1 DIS info in my photo gallery? Car will not start without that 6x signal and the connector gets old and fails. Junkyard and pull a clean used one.
Old 05-18-2019, 12:00 AM   #3
Howiler215
1992 SL1
I will go to a junkyard and grab some new connectors I know I spread them open a bit sticking my meter ends in there. One other thing I just noticed is the Haynes manual says to check the black and white wire for resistance it says it should be 200 ohms. The other end of that wire goes into a splice with some other black and white wires. I have continuity on that wire but my meter says 001. Iím not sure if Iím doing this test wrong but the wire seems fine itís only maybe 5 inches long I have all the tape and plastic peeled back from it.
04 ion 5 speed swap Marksman Ion General 0 05-09-2016 12:06 AM
Cvt to 5 speed swap wkillian Vue Tech 1 10-24-2014 03:43 PM
Who has Done the VTI to 5 Speed Swap 84conv Vue Tech 10 01-20-2014 08:09 PM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
5 speed gear oil change+spark plugs? how hard and what to use YourMainParadox Vue General 5 03-18-2009 03:50 AM
