Old 05-17-2019, 11:42 PM   #1
CierraSimmons
CierraSimmons is on a distinguished road
2008 VUE 3.6L
Default Under hood fuse block fire
I bought my vue xr awd 3.6l used at 208000 miles. It had some existing issues, leaks around the seal of the windshield during weeks of heavy rains, traction control + awd disabled, bad #6 spark plug connector thing, thermostat faulty, needed battery, computer (on top of battery) was replaced in March and either my abs modulator or pump needs replaced. But these repairs were a lot cheaper than the transmission and entire front suspension/control assembly of my dodge.
Yesterday evening I drove 5 miles at most, 15 to 20 minutes after shutting the car off my horn honked for about 5 seconds. I checked my key fob and the buttons weren't stuck, about 2 minutes later it starts honking again but it didn't stop, when I got outside the wipers were going and wiper fluid was squirting out in a steady stream, we started the car checked to make sure the radio and things where turned off and they were. When we popped the hood there was dark grey smoke coming from the fuse block. When I removed the cover every fuse and relay in the block was smoking the worst of it coming from the cluster to the far right. Fire extinguisher didn't put it out, we had to call the fire department. The entire fuse block melted and half of it was burned into crumbling ash/plastic.... It felt like an old foam radiator hose that has dry rotted and then been soaked in old oily water.
Has anyone else had this type of issue? Any ideas what could have caused this?
Add to CierraSimmons's Reputation
Rate the quality of this post and help CierraSimmons reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CierraSimmons is offline   Reply With Quote
2002 Saturn SL2 under hood fuse block mattwithcats S-Series General 1 10-30-2018 10:42 PM
09 VUE under hood fuse block schematic gaurdien 2008 Vue 2 02-11-2017 01:52 PM
Fire in my fuse block velleguy73 S-Series Tech 4 07-06-2011 09:20 PM
need PN 19178429 fuse block prostock53 General Saturn Discussion 1 06-08-2010 12:46 PM
Does fuse block from 96 SL fit 95 SL projectpete19 S-Series Tech 9 07-26-2008 02:38 PM
