Old 04-16-2019, 05:21 PM   #1
Lightfoot2002
Lightfoot2002 has a spectacular aura aboutLightfoot2002 has a spectacular aura about
Default Exhaust manifold questions.
Hello All. For quite some time my 2002 SC2 5 speed with 195k has been running progressively worse. It stumbles and hesitates upon acceleration. The engine heats up to the point of the electric cooling fan coming on. And there is an occasional smell of rotten eggs. And lower mpg.
I saw a rather large crack in the after-market exhaust manifold that is on the car. Could the computer be reading a lean condition and putting more fuel in thus clogging the CAT? I want to replace the after-market exhaust with an original cast iron one. Are there different types of original exhaust manifolds for this year? I see ones with an integrated cylinder CAT, and some without that feature. My engine is a DOHC type. Did it originally come with a integrated CAT?
The previous owner modified the secondary air tube that runs between the diverter valve and the exhaust manifold. Where can I find and original tube that will fit an original exhaust manifold? What year did Saturn start putting in the secondary air pump system and related parts? Thanks for all your help.
Add to Lightfoot2002's Reputation
Rate the quality of this post and help Lightfoot2002 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lightfoot2002 is offline   Reply With Quote
Old 04-16-2019, 06:48 PM   #2
Macgyver
Default Re: Exhaust manifold questions.
All 2001-2002 (and some 2000) S Series came with a pre-cat built into the manifold. Since it sounds like you need the secondary air injection parts, you're going to need to go to a junk yard and pull all of those parts off. Buying them separately on ebay would be too expensive.
Do yourself a favor and drill out the catalyst on the OEM maifold before putting it back on. As the average mileage increases on these S series, the honeycomb is usually in bad shape or clogged as our engines burn oil like crazy. This won't set a check engine light as long as the air injection pump does it's 30 second power on when the engine is cold.
Add to Macgyver's Reputation
Old 04-17-2019, 08:56 AM   #3
Lightfoot2002
Thanks for your info. Could you explain in further detail about drilling out the catalyst on the pre-cat? Is there a hole that gets clogged over time from carbon deposits? Can a used OEM exhaust manifold pre-cat be cleaned with penetrating solvent?
Concerning the secondary air system, all I need is the metal air tube that runs between the diverter valve and the exhaust manifold itself. Does this metal air tube differ in shape and length between a SC1 and a SC2?
Old 04-17-2019, 09:17 AM   #4
trottida
trottida's Avatar
If you look up into the coffee can shaped bottom piece of the exhaust manifold you'll see that it is filled with a honeycomb like material; this is the catalyst he is talking about. It gets clogged and to resolve you hack it out so that it is free flowing. Since you have it off doing it now is a proactive measure so you don't have to deal with it in the future.
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 04-17-2019, 09:38 AM   #5
I removed it from mine when I rebuilt the engine.
Here is the before picture.
Add to Waiex191's Reputation
LSJ Exhaust Manifold on a VUE PortugalFocus Vue Mods 13 07-22-2015 09:16 AM
exhaust manifold? will this fit my vue? DJTricky Vue Mods 12 06-12-2011 09:53 AM
exhaust manifold 96-Sc2 S-Series Tech 7 02-05-2011 10:31 PM
Replacing Exhaust Manifold w/ built in California CC with a Regular manifold salmonito S-Series Tech 6 04-19-2008 11:05 PM
Exhaust Manifold milnimi S-Series Tech 3 06-02-2006 06:27 AM
