Old 04-15-2019, 01:29 AM   #1
civydcex
civydcex is on a distinguished road
Default 01 SL1 SOHC help
I recently did my transmission fluid change and filter. I noticed 1 sensor above and one below the filter. The wire of the upper one was broken. Well the actual plastic piece that connects to the sensor was broken. Exact same connectors as coolant temp sensor IAT sensor so on and so on. What are these two sensors? I assume one is a transmission fluid sensor and possibly temp. Could someone just give me a heads up on what these are I cannot figure it out to save my life and I cannot find anything online at least a diagram would be nice. I've owned this car for about a year now it only has about a hundred forty thousand miles on it and it drives mint. Basically my question is can I replace the wire with a similar wire that the coolant temperature sensor uses because I just replace that and I know where to get that wire. A diagram would be excellent or any link to figure this out. Thanks guys. Have a new member to the site and plan on being on here a while. I never thought I'd own a Saturn but ever since I bought this car I really enjoy it and I found some good info on here to help me so far once again thank you
Add to civydcex's Reputation
Rate the quality of this post and help civydcex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
civydcex is offline   Reply With Quote
Old 04-15-2019, 06:50 AM   #2
Default Re: 01 SL1 SOHC help
civydcex,
Here are the connectors:
https://www.rockauto.com/en/catalog/...connector,2524
Here is a post where I changed that connector.
http://www.saturnfans.com/forums/sho...&postcount=128
I only have manual transmissions so someone else will need to chime in on what is what.
Add to Waiex191's Reputation
Old 04-15-2019, 09:45 AM   #3
see diagrams here
http://www.saturnfans.com/forums/sho...7&postcount=12
http://www.saturnfans.com/forums/sho...d.php?t=233688
Welcome to saturnfans!
I was in the exact same boat. Been here for a decade now
Old 04-16-2019, 04:39 AM   #4
civydcex
That's what I needed. Thanks so much
Old 04-17-2019, 09:20 AM   #5
You're welcome, and welcome to the site!
Impressive amount of info and lots of nice, friendly folks here.
95 SL1 - Installing SOHC auto PCM in SOHC manual RPM rev limit removal / change 3danh S-Series Tech 34 07-21-2017 04:31 AM
2001 SoHC to 1995 Sohc interchange aruschmann84 S-Series Tech 4 04-27-2011 11:56 PM
Engine swap--99 SOHC auto/01 SOHC to fit in 96 SOHC stick comanche S-Series Tech 6 12-02-2008 07:57 PM
Need Advice.engine Exchange,1994 1.9 Sohc To A 1999 1.9 Sohc. Some Issues Include cakjoey S-Series Tech 5 10-08-2006 08:56 AM
upgrade 1991 SOHC TBI to 1995 SOHC MPFI tcotrel Mods and Performance 6 06-06-2002 11:51 AM
