Old 10-27-2003, 04:13 PM   #1
brotherhay
brotherhay is on a distinguished road
Default idle low, already cleaned EGR
Ive got a '93 SL2, and its idling low. It idles at about 800 when not in gear, about 200 when in gear with the brake on. I had a SES code of 26, so I investigated the EGR valve. It was carboned up, so i cleaned what I could see, but didnt get real deep into it. Put it back on and the idle is still low. What is my next logical step, the IAC, or something else. Someone help me out with this please.
Add to brotherhay's Reputation
Rate the quality of this post and help brotherhay reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brotherhay is offline
Old 10-27-2003, 06:55 PM   #2
amazinghl
Default
EGR solenoid.
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 10-27-2003, 07:26 PM   #3
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Default
Perhaps it's time for a new EGR valve.Sometimes with age they just tighten up and don't move smoothly.
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 10-27-2003, 09:11 PM   #4
wolfman
wolfman's Avatar
Default
Unplug the vacuum line running to the EGR valve and plug the hose with a golf tee or small screw. If your idle problem vanishes, the trouble IS with the EGR valve system. If it does not, it lies elsewhere. 800 rpm is right about normal curb idle speed. As it drops only when you put it in gear, it suggests that the PCM is not "seeing" the car being put into gear. A possible nuetral safety switch problem, OR, the IAC valve is sticking and not opening on command of the PCM to up the idle speed in gear..(clean throttle body and IAC valve)
Add to wolfman's Reputation
wolfman is offline
Rough Idle - Changed TPS, ECT, cleaned EGR, sprayed for vacuum leaks. travisj027 S-Series Tech 10 07-06-2009 05:48 PM
Low, uneven idle. Code P1404. EGR problem. Tiger S-Series Tech 0 03-01-2008 08:01 AM
Egr valve, low idle Nagyfasz S-Series General 5 09-28-2007 03:52 PM
cleaned EGR.... 30pack S-Series Tech 7 09-06-2004 09:20 AM
Can an electric EGR be cleaned? "Sadurn" S-Series Tech 9 06-30-2004 10:09 PM
