Old 04-01-2006, 03:19 PM   #1
02VueBeater
02VueBeater is on a distinguished road
Default AWD Carrier bearing?
The carrier bearing on my wifes 02 Vue is crapped out. Is there a factory replacement for that, or do I have to buy the whole prop shaft assy? Thanks.
Add to 02VueBeater's Reputation
Rate the quality of this post and help 02VueBeater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02VueBeater is offline   Reply With Quote
Old 04-01-2006, 03:37 PM   #2
Default Re: AWD Carrier bearing?
Welcome to the Board.
There is a replacement kit availible from Saturn for the steady bearing on the drive shaft for these cars. Comes complete with the steady bearing and a replacement u-joint that needs to be removed to get the steady bearing off.
Add to ssicarman's Reputation
Old 04-01-2006, 03:41 PM   #3
02VueBeater
Thanks alot. You wouldnt happen to have a part number or anything would you on the kit? Or do I just call Saturn garage and ask them for the steady bearing and u-joint kit?
Old 04-01-2006, 11:09 PM   #4
Per a TSB it should be this part number. Best to ask the parts department, the number may have been updated.
10383958
symptoms of failing carrier bearing or CV assembly? 3.5 AWD ls3ftw Vue Tech 3 09-28-2009 11:22 PM
HELP! Propeller Shaft carrier bearing trials183 Vue Tech 1 09-30-2008 08:53 PM
Wheel or carrier bearing vibration? Rivernut Vue Tech 10 08-21-2008 09:24 AM
Prop Shaft Carrier Bearing Replacement? wfransee Vue Tech 3 08-14-2008 01:11 PM
2003 Vue-Carrier bearing gone dawright03 Vue General 10 11-20-2007 05:38 PM
