Old 07-03-2005, 12:09 PM   #1
thrax
thrax is on a distinguished road
Default SL2 Fuel Filter
Ok. So I'm a total moron. I think I know where the fuel filter is, but have absolutely no idea what it looks like. Can anyone help me? And if it's not too much to ask, how about some instructions on how to change it out?
Thanks
Add to thrax's Reputation
Rate the quality of this post and help thrax reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thrax is offline   Reply With Quote
Old 07-03-2005, 12:44 PM   #2
the_new_raceman
the_new_raceman is on a distinguished road
the_new_raceman's Avatar
Default Re: SL2 Fuel Filter
Well its just under and back from the drivers seat. Its a small cylinder with 2 lines in/out of it. Just pry off(but dont break) the lil clips on the lines. Make sure you relieve the fuel pressure by pulling the fuel pump fuse and letting the car run till it dies BEFORE you remove the lines...it makes for a bad day with fuel in your eyes. Pull off the old filter and replace with new. Put the fuse back in and turn the key to the spot BEFORE start...ACC. You should hear the pump prime and re pressurize. It might take a couple starting attempts to get her to go.
If you dont like the tires ur on...change em...now how does that apply to life??? think about it.
Add to the_new_raceman's Reputation
Rate the quality of this post and help the_new_raceman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_new_raceman is offline   Reply With Quote
Old 07-03-2005, 12:54 PM   #3
thrax
Hey Thanks!! I've been searching the net for the last couple hours trying to get that information. I'm glad I found this forum. I'll probably be here for a while.
Thanks again for the info.
Old 07-03-2005, 08:00 PM   #4
wolfman
wolfman's Avatar
91'-97' fuel filters are on the drivers side, below the brake booster, down low where the firewall meets the space frame rail. Silver/gold can looking thing about 4 inches long by 2.5 inches in diameter with a fuel line running in one side and out the other. Remove the driver's side wheel and plastic splash guard for easier access.
98'-02' fuel filters are back by the gas tank. Driver's side mounted to the inside of the frame. Similiar in appreance, but have THREE lines going into/out of it.
Add to wolfman's Reputation
Old 07-03-2005, 08:14 PM   #5
the_new_raceman
Crap i thought it'd be in the same place as my 98 sc2...sorry
Old 07-03-2005, 11:34 PM   #6
twosaturns
twosaturns's Avatar
Thanks
hey I like your ID- look out for osmosis jones! in your member info, put down what car you have- helps us w/ giving info. the filter chage is real easy. just make sure you get the little plastic tool that is supposed to come with it. I thought it was the coolest little setup.
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline   Reply With Quote
Old 07-04-2005, 03:59 PM   #7
the_new_raceman
...i hated the setup
Old 07-04-2005, 08:30 PM   #8
Shinner
Shinner is on a distinguished road
No relief valve on the fuel rail? I've never looked....might be time to change the fuel filter.
Slan,
Jim
Add to Shinner's Reputation
Rate the quality of this post and help Shinner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shinner is offline   Reply With Quote
Old 07-04-2005, 11:23 PM   #9
the_new_raceman
I think there is...im not at home and my book is 5 hours away...ill look when i get home tomorrow night and post if someone doesnt beat me to it. But the way i told is part of the fuel relief process...clears the fuel out of the lines so you dont take a fuel shower.
Old 07-05-2005, 09:07 AM   #10
Shinner
checked in my Haynes manual...there is, though like you said, pulling the fuel pump fuse is part of the procedure.
Slan,
Jim
Old 07-06-2005, 12:07 AM   #11
the_new_raceman
Knew it LOL so where is the valve and how do you relieve the pressure.
Old 07-06-2005, 12:45 AM   #12
Shinner
on the fuel rail...I had a quick look but my wife only just had gotten home so the engine bay was pretty hot. Looked like it might be on the right end (driver's side of the car)
Slan,
Jim
Old 07-06-2005, 12:52 AM   #13
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
pull the fuel pump relay and run the car til it dies u will relive the pressure and not get gas all over
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 07-06-2005, 10:05 AM   #14
the_new_raceman
^^^i already posted that...i meant from the valve,^^^
Old 07-07-2005, 03:50 PM   #15
cris_thomas
cris_thomas is on a distinguished road
cris_thomas's Avatar
Step by step instrcutions with pictures for the 98-02 fuel filter are posted here
http://www.cristhomas.com/cars/FuelF...lterHowTo.html
- Cris Thomas
SPOC New England
http://www.spocne.org
Add to cris_thomas's Reputation
Rate the quality of this post and help cris_thomas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cris_thomas is offline   Reply With Quote
Old 07-07-2005, 04:14 PM   #16
Shinner
Nice writeup Chris....only thing I would add is to throw a couple of cinder blocks or 4x4s under the body/frame in case either the jack or stands slip.
Didn't realize the filter is good for 100K...think I can put off changing the one in my wife's car for a while...she's got about 78K on it I think.
Slan,
Jim
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 07:29 AM
Fuel filter (96 SL2) 12:oc7ock S-Series General 3 07-15-2006 09:26 PM
'96 SL2 fuel filter... volsfan S-Series Tech 2 03-12-2005 09:30 PM
Fuel Filter on 92 SL2 Rogn38 S-Series Tech 11 02-07-2005 11:06 PM
98 SL2 Fuel Filter brerrabbit23 S-Series Tech 2 08-10-2002 12:37 AM
