Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 06-18-2005, 04:55 PM   #1
lownslow
lownslow is on a distinguished road
lownslow's Avatar
Default after market tach install
i recently purchased an autometer 5" tach with an external shift light, i have one proplem. the green wire coming of the tach goes to the tach signal wire. so i looked up my car on my omega wiring disc we have at the body and performance shop i work at. it said that it that the tach signal wire is a white wire located at the pcm. so i took the top part of the dash off so i can access the pcm, but there is four white wires. i know that the green wire cannot get connected to twelve volt source,which three of the wires did. i connected the green tach wire to the white pcm wire that i thought was correct, but the tach is not working proporly.when i rev the car,the factory tach will be for example at 1500 rpm. now the autometer tach will only read 500 rpm. that is where i am having problems. i wanted to know if i have the right white wire or if i dont do i need to connect it to another one of the 3 white wires on the pcm so the tachs read somewhat similar. or it could be possible the diagram i used was wrong. if so, i need to know what wire is the tach signal wire. any help at all would greatly be appreciated.
Add to lownslow's Reputation
Rate the quality of this post and help lownslow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lownslow is offline
Old 06-18-2005, 05:10 PM   #2
casper saint
casper saint is on a distinguished road
casper saint's Avatar
1993 SW2
Default Re: after market tach install
Most aftermarket tacs have a button on the back to switch from 4, 6, and 8 cyls being that you at least get a signal you should probaly check to see if it is switch to 4 cyl instead of 8.
Add to casper saint's Reputation
Rate the quality of this post and help casper saint reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
casper saint is offline
Old 06-19-2005, 12:52 PM   #3
lownslow
lownslow's Avatar
this particular tach doesnt have a switch to do that. instead it has two wire lumes on the back of it. you leave both of them connected for a v8, cut one of them for a v6, or cut both of them for 4cly. and i did cut both. the tach does work, but it is close to 1,000 rpm off verses the factory one.
lownslow is offline
Old 06-19-2005, 02:50 PM   #4
cris_thomas
cris_thomas is on a distinguished road
cris_thomas's Avatar
Call Autometer. Their tech support is top notch and will help you through your install.
Alternatively do a search here. There is a big long post here somewhere from when I installed my shift light a few years ago. I seem to remember tapping into the white (or was it green?) wire that came out of the ignition modules.
- Cris Thomas
SPOC New England
http://www.spocne.org
Add to cris_thomas's Reputation
Rate the quality of this post and help cris_thomas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cris_thomas is offline
Old 06-29-2005, 05:36 PM   #5
lownslow
lownslow's Avatar
thanks dude. ill definately have to try that.
lownslow is offline
how do you install after market stereo? black13 Ion Mods 10 08-04-2008 10:18 AM
Need Help!! How Do I Install An Aftermarket Tach?!!! delagumi18 Ion Red Line 0 02-29-2008 05:46 PM
Question about after market Tach 1992SaturnSL2 Mods and Performance 5 10-03-2005 11:45 PM
after market tach install lownslow S-Series Tech 13 06-29-2005 05:25 PM
