Old 03-03-2005, 11:18 AM   #1
musicman2005
musicman2005 is on a distinguished road
Default Camshaft Sensors
1997 Saturn SL1
My service engine soon light came on after warming up my car yesterday (did not come on after running car cold later in the day) It's running OK. I went to Advance Auto Parts and did a code scan - it came up with
Camshaft Position Sensor A
P0341
Is this sounding right guys? Something I can easily replace/fix on my own?
Thanks
MM
Add to musicman2005's Reputation
Rate the quality of this post and help musicman2005 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
musicman2005 is offline
Old 03-03-2005, 01:29 PM   #2
nashville0303
nashville0303 is on a distinguished road
Default Re: Camshaft Sensors
I think you need a tune up. I had the same code along with a misfire code. If the light goes out I think that means it's just temporary but maybe your plugs are spent. It will probably come back. A tune up worked for me.
Add to nashville0303's Reputation
Rate the quality of this post and help nashville0303 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nashville0303 is offline
Old 03-03-2005, 01:31 PM   #3
nashville0303
First thing I'd do is change the plugs if they haven't been replaced in a while. That's a $5 fix if it works and new plugs are a good thing anyway if it doesn't.
Old 03-04-2005, 01:04 AM   #4
sierrap615
sierrap615's Avatar
http://www.saturnfans.com/forums/showthread.php?t=43380
sierrap615 is offline
Old 03-07-2005, 02:32 PM   #5
billbat
billbat is on a distinguished road
2001 L-Series 3.0L Sedan
Happy Re: Camshaft Sensors
yup
i had the same problem
i changed the spark plugs and wires
viloa
no ses light
bill'
Add to billbat's Reputation
Rate the quality of this post and help billbat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
billbat is offline
Old 03-07-2005, 11:15 PM   #6
Since it hasn't been said yet, these cars have no cam position sensor. That code, then, points to an ignition problem, e.g. plugs, wires, grounding of the coil packs / module.
Add to madpogue's Reputation
madpogue is offline
Old 03-11-2005, 11:03 PM   #7
tazunemono
tazunemono is on a distinguished road
Hah just replaced a head, didn't see a cam sensor.
Saturns have a crank sensor used for timing and emissions control. The new plugs/wires idea is a good one. Air filter? Just get a tune up.
Add to tazunemono's Reputation
Rate the quality of this post and help tazunemono reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tazunemono is offline
Old 03-12-2005, 07:24 AM   #8
jeep4523
jeep4523 is on a distinguished road
Volvos and Fords and some Chryslers may use cam sensors, but the Saturn PCM engineers were smart enough to figure out that when the crank is in a given position, the camshaft will also be in a given position, and they simplified life a little bit.
Gotta love 'em :-)
Democracy is two wolves and a sheep voting on what to have for dinner. Liberty is a well armed sheep contesting that decision.
Add to jeep4523's Reputation
Rate the quality of this post and help jeep4523 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeep4523 is offline
Use Saturn oem O2 sensors or generic sensors? 2strkBlu S-Series Tech 25 08-09-2016 02:55 PM
camshaft sensing RobertGary1 S-Series Tech 9 01-07-2010 07:23 PM
Camshaft Removal Clickety_Clack S-Series General 0 12-07-2008 04:10 PM
camshaft replacement afcs S-Series Tech 3 02-24-2007 03:08 PM
Camshaft upgrade sspriest S-Series Tech 1 05-26-2001 11:14 PM
