Old 11-27-2019, 04:57 PM   #1
Eiron
Eiron will become famous soon enoughEiron will become famous soon enough
Eiron's Avatar
1999 SW2
Default Is this the correct valve cover hose?
The SW2 needs the hose from the front valve cover to the air intake plenum (on the right side of the engine). I think this provides fresh air when the PCV opens? I found this hose on Amazon but I can't tell from the dimensions if it's the correct hose or not. I measured the hose at 7" long in the straight section (from elbow to elbow). Anyone know?
He's dead Jim!
You grab his tricorder, I'll get his wallet.
Add to Eiron's Reputation
Rate the quality of this post and help Eiron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eiron is offline   Reply With Quote
Old 11-27-2019, 05:08 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Is this the correct valve cover hose?
Yes, but you can save a few dollars and pick it up at advance auto, and use 20-25% off by ordering on line and picking it up at the store.
If the snow storm is not too bad, Loveland, CO has 2 of their stores.
Dorman 46060.
https://shop.advanceautoparts.com/p/...060/11077101-P
Old 11-27-2019, 05:26 PM   #3
Eiron
Eiron's Avatar
1999 SW2
Thanks for the confirmation! I didn't even think of checking locally...
He's dead Jim!
Old 11-27-2019, 05:37 PM   #4
Or save a few more dollars and use generic rubber hose. I think they sell fuel line by the foot or inch at the store.
It ends up being an S-shape because it doesn't have the nice 90 degree bends, but it has worked fine in my 98 SL2 for many years
probably paid $1 for that, years ago
Old 11-27-2019, 05:39 PM   #5
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
I used Prestone for $3.49 at O'Reilly. I believe part number FU0308. I just used the whole 2 foot length.
1999 SL2 A4 -86k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 11-27-2019, 06:00 PM   #6
Eiron
Eiron's Avatar
1999 SW2
The official snow total from the city was 20", but I'm up on a hill and only got 15" at my house. Unfortunately, the city doesn't plow my neighborhood and none of my cars have more than about 9" of ground clearance.
He's dead Jim!
Old 11-27-2019, 06:21 PM   #7
toggenburg
toggenburg's Avatar
^^ Lots of snow, somehow I'm not sure Amazon Prime (UPS) would get the online part any faster than you eventually getting to the local parts store.
I used ordinary tubing once for the same 'repair', but I didn't like the look, so I got the correct pre-bent tubing and went that route instead.
Old 11-28-2019, 12:51 PM   #8
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Rock Auto
https://www.rockauto.com/en/catalog/...on)+hose,11784
Make sure you get some clamps to hold it on..
https://www.rockauto.com/en/partsearch/?partnum=13400
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 11-28-2019, 01:04 PM   #9
454cid
Originally Posted by mattwithcats View Post
Hmm, I've never found that hose before.... Only the Dorman is listed for my 2000.
I don't think GM used clamps on that hose originally. It should be under vacuum, although, I think mine is pressurized now.
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-28-2019, 02:50 PM   #10
Eiron
Eiron's Avatar
1999 SW2
Thanks for the ideas alordofchaos and NWSaturn247, but my nature forces me to side with toggenburg on this one!
mattwithcats, RockAuto won't ship to me any more due to the recent changes in internet tax laws (separate rates for cities vs states).
Luckily Amazon's prices are often comparable!
He's dead Jim!
Old 11-28-2019, 06:43 PM   #11
NWSaturn247
I figured this setup might minimize risk of oil vapor intrusion. Regardless, Goldie runs like a top.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 11-29-2019, 01:50 PM   #12
Eiron
Eiron's Avatar
1999 SW2
That looks like decent routing for that hose
He's dead Jim!
Correct Front Cover Bolts? Ruger141 S-Series Tech 3 03-25-2012 01:46 AM
Is my EGR valve correct? nickfeakes S-Series Tech 13 03-03-2009 04:52 PM
brass fitting near oil cap on valve cover, where does hose go? mikes 1994 z28 S-Series General 1 08-05-2006 02:06 PM
Who sells the correct lower radiator hose for the 92 SL DOHC? turbobuick33 S-Series General 2 11-26-2005 12:36 PM
valve cover to intake hose coming off... LI 350 S-Series Tech 19 07-06-2001 11:06 PM
