Old 08-23-2019, 06:30 PM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default Timing cover
Does anyone know if the timing cover or anything around it is going to be tough to get loose? Iím about to replace water pump and I was watching a you tube video and the guy had to grind a bolt off. Also, when would be the best time to raise the motor? Before I loosen mount bolts or after?
Tyson is offline   Reply With Quote
Old 08-23-2019, 10:55 PM   #2
Default Re: Timing cover
Did you try searching past threads of L300 members posting their experiences when replacing timing chain and water pump? Snapshots included.
crank position for timing without removing the timing cover 03232001 S-Series Tech 9 10-03-2015 06:59 PM
sounds like the timing chain coming in contact with timing cover prioris S-Series Tech 3 12-08-2012 01:12 AM
timing chain sounds like it could be coming into contact with timing cover prioris Sky Tech 0 12-07-2012 10:31 PM
What problems can be diagnosed / fixed under the valve cover / timing cover? Dalamar S-Series Tech 1 09-15-2011 09:42 AM
Timing cover for 96 SL2 dkriss S-Series General 5 11-19-2009 01:41 PM
