Old 08-11-2019, 09:24 AM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default ignition starter switch
this might seem like a silly question. I replaced my ignition cylinder lock a month or so ago. But, the problem I'm having I believe is coming from ignition switch. I've been reading about them and noticed that not all vehicles have the switch I think I need. Because I do have 2002 l300 can someone tell me if I do have the ignition starter switch? And if so, does it require me taking steering wheel off or just the plastic around it? I'm thinking it's behind the cylinder lock or under. Please help!?
Add to Tyson's Reputation
Rate the quality of this post and help Tyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tyson is offline   Reply With Quote
Old 08-11-2019, 12:06 PM   #2
ernesto rex
ernesto rex is on a distinguished road
ernesto rex's Avatar
2000 L-Series 3.0L Sedan
Default Re: ignition starter switch
Hello Tyson,
Question: What kind of problem are you having?
The stering colum cover on my 2000 LS2 is held togeather by three hex head bolts and some snap fittings. Not sure if Saturn went to Torx fasteners on the covers by 2002. Pretty easy to take off.
2000 LS2
2003 VUE 3.0 FWD
2002 MINI Cooper R50
1978 GMC PU 7.4L
Add to ernesto rex's Reputation
Rate the quality of this post and help ernesto rex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ernesto rex is offline   Reply With Quote
Old 08-11-2019, 01:03 PM   #3
pierrot
pierrot's Avatar
Yes, there is an ignition switch. (The link below is for reference only.)
https://www.gmpartscenter.net/auto-p...tion-lock-scat
The covers have to be removed. I can't recall if the screw heads on the covers are allen style female hex or female torx, but start with the allen head type first and if they don't fit then use a torx bit. The steering wheel remains in place, but be sure to disable the airbag prior to working in this area. The switch is on the lower left side of the column to avoid accidental deployment. Two electrical connectors and two mounting bolts are removed to take out the switch. I would highly recommend purchasing a Haynes Repair Manual. It's quite useful for the DIYer and I make much use of it myself. This information was found there.
325,000 miles - Holy canolli!
Add to pierrot's Reputation
Starter, Solenoid, Ignition Switch??? silverslp S-Series Tech 12 01-12-2015 05:44 PM
possible bad starter or ignition switch? Hewjerome S-Series Tech 9 11-26-2007 11:04 PM
Clutch switch and Starter Relay / Ignition wx_junkie S-Series Tech 4 02-12-2007 06:41 PM
Is it the Ignition Switch or the Starter? Scout238 S-Series Tech 15 05-17-2006 05:51 AM
starter...or ignition switch...maybe solenoid timmu S-Series Tech 8 06-20-2005 12:59 PM
