Old 08-09-2019, 12:13 PM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default Cutting fuel lines
Can I cut 2 feet of fuel line by right rear tire and replace it with rubber hose? And if so how?
Add to Tyson's Reputation
Rate the quality of this post and help Tyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tyson is offline   Reply With Quote
Old 08-09-2019, 02:34 PM   #2
Default Re: Cutting fuel lines
Are your fuel pipes resembling mine? http://www.saturnfans.com/forums/sho...d.php?t=222339.
The larger pipe was fine although it looks worse overall. The smaller vent pipe corroded right thru at the bracket mount and split as I removed the assembly. Rockauto replacement was the way I went. Others found clean junk yard replacements. I never thought of cutting and splicing in rubber hose but it may be possible as long as you realize this mod may have pitfalls.
Cutting the larger pipe to fit a rubber hose to slip onto two remaining pieces has its hazards. You'll have to find fuel compatible hose (rockauto states 2" inside diameter) and not just plain rubber because non compatible hose will break down from fuel and disintegrate into the tank to clog the fuel sock - the primary fuel filter before its pumped into an external fuel filter near the area. Fuel resistant hose at least 2 inches in diameter will fit tightly over rusted pipe (sanded down as smooth as possible and lubed with oil or dishwashing detergent to slide on). The next problem is if the pipe is cut to remove the bracket mount. If the bracket mount is removed along with the pipe, you'll have to come up with a way to either reuse the mount or create a new one as a clamp around the rubber hose and mount it to the chassis. Galvanized metal used as straps outdoors or some thin gauge stainless band clamp with metal to serve as a hole for mounting to chassis. Stainless worm clamps should do for clamping rubber hose over rigid pipe.
The same efforts goes to cutting and splicing fuel resistant small diameter hose for the vent line. Both can be cut with a plain hack saw. Clean out all metal shavings to prevent then from getting into the fuel tank when everything's assembled together to put back onto the car.
Old 08-09-2019, 09:31 PM   #3
Tyson
My concern is, if I cut the pipes and put new hoses on will they blow off?
Old 08-09-2019, 09:42 PM   #4
No pressure on the large fuel feed or the vent pipe. The main fuel tank is the non pressurized side; main tank and vent line are not pressurized because it feeds fuel to the fuel pump that pressurizes fuel sent to the fuel filter outside the tank. Once tank pump runs, normal fuel sitting in the tank is sucked into the inlet side of the pump, pressurized to 38-44 psi and sent to the fuel line towards the injector rail. Tank pressure is hardly higher than 1 or 2 psi. Remember, every time you remove the fuel cap to refuel, no large hissing sounds to tell you a large pressure is released.
Regular fuel resistant hoses and stainless clamps is all that's needed. No high pressure blow off potential.
Old 08-09-2019, 09:50 PM   #5
Tyson
Ok so the lines coming from where I fill up with gas going to drivers side is all good to cut. Because I only need to cut an 2 feet of small line. And you said that is the vent right?
Old 08-09-2019, 11:52 PM   #6
Both fuel (large diameter pipe) and vent (small diameter pipe) are not under high pressure at any time. Although I don't recommend what you're doing, the suggestions to cut and splice in fuel resistant hoses using clamps as a temporary repair is a risk you assume for any hazards making modifications that aren't part of regular maintenance. Your choice, your risk for any mistakes made.
The large pipe is the main fuel line from fuel inlet on the side of the car to the fuel tank. The small diameter pipe is the vented fuel from the tank going to the vent solenoid mounted next to the fuel filler hole. Review the link I posted.
Old 08-10-2019, 07:30 AM   #7
Dsaturn
Dsaturn is just really niceDsaturn is just really niceDsaturn is just really niceDsaturn is just really nice
2001 L-Series 2.2L Sedan
I think there is a little confusion here. What diameter are these lines you are wanting to cut?
https://www.infowars.com/
Add to Dsaturn's Reputation
Rate the quality of this post and help Dsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dsaturn is offline   Reply With Quote
fuel lines Tyson L-Series General 6 08-12-2019 08:25 PM
Fuel electrical lines Rez S-Series Tech 1 01-21-2018 09:20 PM
Fuel Lines for '95 DOHC mjo S-Series Tech 7 07-05-2006 02:58 AM
cutting the fuel pump circuit paulygon S-Series General 4 09-29-2005 02:49 PM
Do I need to replace fuel lines W/ fuel Filter? donisaacs S-Series General 2 11-16-2003 08:23 PM
