Old 04-14-2016, 12:14 PM   #1
oxfordbrent
oxfordbrent is on a distinguished road
Default 2004 Vue Automatic Loc issue
I have a 2004 Vue FWD VD that recently has had an issue with the automatic door locks. The button on the door doesn't work, but the doors do automatically lock if I put the car in drive. A workaround to be able to lock all doors including the hatch that I've been doing is to put it in drive, let it lock all doors automatically and then cut the engine off before putting it back in park. Is this a fuse issue and if so, which one? Thanks
Add to oxfordbrent's Reputation
Rate the quality of this post and help oxfordbrent reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oxfordbrent is offline   Reply With Quote
Old 04-14-2016, 12:49 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2004 Vue Automatic Loc issue
Welcome to Saturn orphan central.
More questions than answers at this point:
1. So, you don't have keyless entry?
2. Have you tried front passenger door/unlock switch?
3. Will either switch unlock doors after you use your method to lock?
Its probably safe to say BCM and lock and unlock relay network is still working OK.
This does leave you with possibly one or more bad switches or perhaps broken wire in door hinge area.
We'll be able to provide better assistance after you answer questions.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 04-14-2016, 01:19 PM   #3
oxfordbrent
Thanks for taking a look at this!
1. So, you don't have keyless entry? no
2. Have you tried front passenger door/unlock switch? Yes, neither works
3. Will either switch unlock doors after you use your method to lock? No, I can only unlock manually by pushing the knob open on each door or by cranking the car and it automatically opens all doors.
Last edited by oxfordbrent; 04-14-2016 at 01:21 PM.. Reason: Unnecessary text copied into post
Old 04-14-2016, 02:22 PM   #4
far2grumpy
far2grumpy's Avatar
Check for blown LOCK/MIRROR 10A fuse in Instrument Panel fuse block.
The cover would be next to seated front passengers left foot and there's a map on back of cover.
2004 Ion Coupes with a 5 speed automatic? FnKVn Ion General 19 08-29-2013 10:31 PM
Automatic transmission issue trottida S-Series Tech 0 05-16-2011 11:29 AM
Automatic transmission issue mikewinva S-Series Tech 1 05-09-2011 08:33 PM
automatic seabelt issue AmericanImport S-Series Tech 15 03-21-2008 12:50 AM
2004 Ion 5 speed Automatic Transmission fredrick Ion General 2 10-22-2004 12:13 PM
