Old 10-19-2014, 12:08 PM   #1
nickbrit16
nickbrit16 is on a distinguished road
Dizzy Camshaft position sensor?
Hi all, I bought a 1998 Saturn sl2. When I bought it the service light was on. Took it to oreilly auto parts and they ran a scan and said it was the camshaft position sensor. When I start my car in the morning it runs rough for about 10 seconds and I have to give it has to keep it running, then it smooths itself out and runs like a champ. I've replaced the fuel regular/filter with the OEM thinking that was the problem but it wasn't. Any ideas? Could this be the starting issue?
Add to nickbrit16's Reputation
Rate the quality of this post and help nickbrit16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nickbrit16 is offline   Reply With Quote
Old 10-19-2014, 06:31 PM   #2
Steve44
Steve44 is just really niceSteve44 is just really niceSteve44 is just really niceSteve44 is just really nice
Steve44's Avatar
1999 SL1
Default Re: Camshaft position sensor?
S-Series do NOT have a Cam position sensor. The usual cause of that code is because you could use a new set of plugs and or wires. Make sure to get NGK Coppers (DOHC Spark Plugs : BKR5ESA-11 (NGK: 5643) Be sure to get the best quality wires you can as well.
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-19-2014, 10:18 PM   #3
SL19302
SL19302's Avatar
2002 SL1
As mentioned new plugs and wires and make sure the coil towers and coil grounds are clean and free of corrosion.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 10-19-2014, 10:18 PM   #4
nickbrit16
So why does the code say cam postion sensor? Just had a tune up done also. Possible coolant sensor?
Old 10-19-2014, 10:26 PM   #5
SL19302
SL19302's Avatar
2002 SL1
Heres a Youtube video that explains all your questions and repairing that trouble code on your car.
http://www.youtube.com/watch?v=i_y-3fhAHZM
CHECK YOUR OIL!
Camshaft Position Sensor :P brokendown S-Series General 10 02-18-2013 10:37 PM
Camshaft Position Sensor avlonfrg S-Series Tech 9 08-11-2012 03:17 AM
Camshaft Position Sensor scrooloose 2008 Vue 4 04-20-2012 05:34 PM
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
Camshaft Position Sensor on a 96 SC2... DJboozeAlot S-Series Tech 15 12-06-2006 08:38 PM
