Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 07-25-2012, 12:55 AM   #1
sparkynsmoke
sparkynsmoke is on a distinguished road
sparkynsmoke's Avatar
2005 RELAY-2
Default A/C button stopped working
I just replaced the original battery on my Relay 2 and my A/C button suddenly stopped working. Do I have to replace the ENTIRE faceplate for the A/C and heating element, or is there a way to just replace the button? I'm getting [I]really[I] frustrated with the fact that mostly everything with the Relay's quickly becoming "dealer only". If that's the case, I'm getting rid of it and getting a Chevy!
1995 SL2 - Sparky- (234K+)
1997 SW2 - Smoke- (64,817) RIP my little boy
2004 Chevy Cavalier - Gordy- (103K+)
2005 Relay 2 - Swoop or Smoke II- (48K+)
Add to sparkynsmoke's Reputation
Rate the quality of this post and help sparkynsmoke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sparkynsmoke is offline   Reply With Quote
Old 07-25-2012, 01:20 AM   #2
Default Re: A/C button stopped working
There are two bulletins;
1-#05-01-38-014: A/C Temperature andMode Controls Inoperative, A/C Button Does Not Respond When Pressed, Pushbutton LED Indicators Brighter Than Rest of HVAC Control Head (Update HVAC Control Module Software) - (Oct 5, 2005)
Some customers may comment on any of the following conditions:
The Heating, Ventilation and Air Conditioning (HVAC) system will not change modes when the customer selects a mode change.
The Air Conditioning (A/C) button is not functional. It does not respond when pressed.
When the headlights are on and the dimmer switch is at its maximum position, the pushbutton Light Emitting Diode (LED) indicators will be brighter than the rest of the HVAC control head.
On a vehicle with single zone control heads the temperature function will not operate properly.
A new calibration has been released to correct these conditions. Reprogram the HVAC Control Module with software/calibrations contained in GMNAO TIS version 9.5 or later, which was released on September 18, 2005.
2-#06-01-39-004E: EI06031 - HVAC Unable to Change Modes or Temperature, Inoperative, Poor A/C Performance (Reprogram HVAC Control Module) - (Feb 8, 2008)
Some customers may comment that they are unable to change the HVAC mode and/or temperature. Customers may also comment that the A/C may be inoperative or have poor performance.
Cause
Engineering has determined based on technician feedback that this concern may be caused by not having the updated HVAC control module software or due to a communication issue between the temperature door actuator and the control head.
Correction
Reprogram the HVAC Control Module with the latest calibration set to correct this issue.
A call to your local GM dealer is needed to see if yours was updated.
A/C stopped working lodingi Vue Tech 6 07-24-2011 10:28 AM
AC stopped working outdoorman S-Series Tech 14 05-27-2011 03:34 PM
AC stopped working cboss S-Series General 8 04-05-2010 05:06 PM
AC stopped working jonnycube S-Series General 14 07-25-2009 07:56 PM
Fan stopped working EllenJ2001 S-Series General 2 03-14-2004 04:13 AM
