Old 10-21-2010, 06:59 PM   #1
umoms
umoms is on a distinguished road
Default 2003 Saturn Vue Tranmission Issues
I just bought a 2003 Saturn Vue with the VTi Transmission. It is 2.2L 4-Cylinder FWD and Automatic with 111k miles
I bought it from a dealer and after driving it for 30min it wouldn't move and i got stuck on the expressway. It wouldn't move at all anymore. I waited a hour for a tow truck and got sick of waiting so I started the car and it was driving again..Although 1st gear felt it was slipping.
I got it home and parked it. The check engine light came on while driving and I got the codes
P0300 P0741 P0700
I checked the transmission reservoir and it seemed low. So i drained the transmission fluid and I went to the parts store and they told me I could use Dex/Merc transmission fluid. So i drained the old fluid and put the new one in and I drove it around the block then I lost all gears except reverse. I let it run and cool off and tried again and nothing... I tried on both cold and warm starts and I have nothing but reverse now.
After doing much research I read that I am suppose to use the Dealer CVT Transmission fluid plus additive. Which is $66 bucks for the gallon and $25 for the additive.
My question is do you think I ****ed something up by replacing the trans fluid? It seemed like it got worse. Should I drain it again and put the dealer CVT transmission fluid with the additive? Or is the Dex/Merc fluid fine?
Can i get the CVT transmission fluid+additive cheaper elsewhere?
Or am I screwed and I have to get the transmission rebuilt?
Add to umoms's Reputation
Rate the quality of this post and help umoms reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
umoms is offline   Reply With Quote
Old 10-21-2010, 08:57 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2003 Saturn Vue Tranmission Issues
P0300 P0741 P0700
Oh no! Is there no warranty of any shape, form or fashion?
The "dealer" must have known these things are time-bombs. If they refuse to take the vehicle back - or assist with repair - you should see if your state has a "used" vehicle consumer protection clause, and if not, I'd see about filing with small claims court (assuming repair cost doesn't exceed local value for small claims .
You can find CVT fluid data in post # 3 of following thread:
http://saturnfans3.saturnfans.com/~s...d.php?t=142234
I suppose there's a minute chance the transmission could be revived with the correct fluid and additive but I wouldn't bet a toothpick on the outcome.
It also appears replacing the fluid is only slightly less complicated than a trans rebuild.
I feel so sorry for you.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 10-23-2010, 08:58 PM   #3
baisley
baisley is on a distinguished road
2003 VUE 2.2L
I am dealing with this on my other 03 Vue as well. My car does the same, it drives fine when it's cold, then it will start to slip as it warms up. The trans is shot. There is a pressure leak internally and the unit needs to be rebuilt.
Personaly, I would buy 2 gallons of the fluid and do a flush. You basically dump the existing fluid, then refil with the 4 quarts, drive the car or at least run it back and forth on the driveway several times, dump the fluid and refill one more time.
Call the dealer and tell them that the car died on the expressway and the trans is junk. There should be some sort of lemon law in your state. Dont think about fixing the car either.. a rebuilt (non saturn facility) will charge around 2600 for the rebuilt trans andadd labor on top. Saturn will charge around 5K for the job. The trans will always be a time bomb.. you'll never feel safe in it.
I am lucky as I bought my back in 04, from a wrecking yard with 11K on it. I have 108K now, it gets me to the airport with no issues, but I have no faith it in. The only thing of value in the car is a screw driver, once the car fails, I will pull the plates and call a cab!
Run away from this car... it's not worth your time or effort. Get a newer one or a V6 with the Asian trans or a manual. These are great cars, but the VTI is garbage.
Add to baisley's Reputation
Rate the quality of this post and help baisley reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
baisley is offline   Reply With Quote
Old 10-24-2010, 11:35 AM   #4
marwanco
marwanco is on a distinguished road
Hello,
This is my experience with VTI.
I decide to change oil myself, by mistake I opened the transmission bolt and drained the whole thing into a clean pan.
When I realised that it smelled not like oil, I poored the whole thing back into transmission with a funnel, nothing happened.
And why transmission should be so sensitive to the fluids? I cant visualize how wrong fluid can damage a transmission, maybe degrade the performance,
but if flushed and replaced with proper fluid, everything must work again.
Add to marwanco's Reputation
Rate the quality of this post and help marwanco reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marwanco is offline   Reply With Quote
Old 10-24-2010, 09:44 PM   #5
The Math God
The Math God is on a distinguished road
The Math God's Avatar
sounds like your Tranny may be very close to being shot
2007 Vue -- AWD 3.5 Honda
2005 Vue -- AWD 3.5 Honda
2007 Ion 2 -- 2.2
2005 L300 -- 6 cyl
Gone but not forgotten
2003 Vue -- 105K-traded in
2000 LS 2 --140 K-totaled
1994 SL-- 100K-sold
Add to The Math God's Reputation
Rate the quality of this post and help The Math God reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Math God is offline   Reply With Quote
Old 10-27-2010, 01:20 AM   #6
spitfire22
spitfire22 is on a distinguished road
P0300 P0741 P0700
Have you heard anything about what is happening with those Saturn Vues? I would take it back to the dealership and get your money back. THey have faulty transmissions in them, There is a class action lawsuit against Saturn for theses faulty transmissions. They are Saturn Vues from 2002-2006 the 4 cyl. AWD. I own one and the transmission went out. Now I am stuck with it
and getting no help from Saturn because I have 117 miles on it... Take it back they may have sold you a Lemon I think so....
Add to spitfire22's Reputation
Rate the quality of this post and help spitfire22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spitfire22 is offline   Reply With Quote
Old 10-27-2010, 04:53 PM   #7
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Originally Posted by marwanco View Post
Hello,
Automatics are hydraulic devices, they are engineered to operate with fluids with certain specific properties. If you use a different fluid the transmission can slip, ship harshly, or be damaged.
Add to BobbyP's Reputation
2003 V6 vue with motor issues. conquest_tsi Vue Tech 10 11-17-2010 11:57 AM
2003 ION Staring Issues spmcoastie Ion Tech 14 01-23-2010 09:00 PM
95' SC2: charing system/tranmission issues xanderdavis S-Series Tech 3 01-11-2010 12:38 PM
2003 Saturn VUE - Security Light & Power Steering issues Bridgette Vue Tech 5 10-29-2007 03:46 PM
2003 VUE Issues rwebb71 Vue General 14 05-29-2006 07:30 PM
