#1 |
![]() Join Date: Jul 2005
Ok. So I'm a total moron. I think I know where the fuel filter is, but have absolutely no idea what it looks like. Can anyone help me? And if it's not too much to ask, how about some instructions on how to change it out?
![]() Thanks |
#2 |
Well its just under and back from the drivers seat. Its a small cylinder with 2 lines in/out of it. Just pry off(but dont break) the lil clips on the lines. Make sure you relieve the fuel pressure by pulling the fuel pump fuse and letting the car run till it dies BEFORE you remove the lines...it makes for a bad day with fuel in your eyes. Pull off the old filter and replace with new. Put the fuse back in and turn the key to the spot BEFORE start...ACC. You should hear the pump prime and re pressurize. It might take a couple starting attempts to get her to go.
If you dont like the tires ur on...change em...now how does that apply to life??? think about it. |
#3 |
Hey Thanks!!
![]() Thanks again for the info. |
#4 |
91'-97' fuel filters are on the drivers side, below the brake booster, down low where the firewall meets the space frame rail. Silver/gold can looking thing about 4 inches long by 2.5 inches in diameter with a fuel line running in one side and out the other. Remove the driver's side wheel and plastic splash guard for easier access.
98'-02' fuel filters are back by the gas tank. Driver's side mounted to the inside of the frame. Similiar in appreance, but have THREE lines going into/out of it.
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
#5 |
Crap i thought it'd be in the same place as my 98 sc2...sorry
#6 | |
![]() Quote:
for the first time in 8 years, I don't own a saturn. |
#7 |
...i hated the setup
#8 | |
![]() Join Date: Jun 2005
![]() Quote:
Slan, Jim |
#9 |
I think there is...im not at home and my book is 5 hours away...ill look when i get home tomorrow night and post if someone doesnt beat me to it. But the way i told is part of the fuel relief process...clears the fuel out of the lines so you dont take a fuel shower.
#10 | |
![]() Quote:
Slan, Jim |
#11 |
Knew it LOL so where is the valve and how do you relieve the pressure.
#12 | |
![]() Quote:
Slan, Jim |
#13 |
![]() Join Date: Jan 2005
1994 SL1
pull the fuel pump relay and run the car til it dies u will relive the pressure and not get gas all over
Carmen
1998 2.4L swapped Plymouth neon is my ride. |
#14 |
^^^i already posted that...i meant from the valve,^^^
#15 |
Step by step instrcutions with pictures for the 98-02 fuel filter are posted here
http://www.cristhomas.com/cars/FuelF...lterHowTo.html
- Cris Thomas SPOC New England http://www.spocne.org |
#16 | |
![]() Quote:
Didn't realize the filter is good for 100K...think I can put off changing the one in my wife's car for a while...she's got about 78K on it I think.
Slan, Jim |
Bookmarks |
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? | 2003MercMaraude | S-Series Tech | 2 | 10-17-2008 07:29 AM |
Fuel filter (96 SL2) | 12:oc7ock | S-Series General | 3 | 07-15-2006 09:26 PM |
'96 SL2 fuel filter... | volsfan | S-Series Tech | 2 | 03-12-2005 09:30 PM |
Fuel Filter on 92 SL2 | Rogn38 | S-Series Tech | 11 | 02-07-2005 11:06 PM |
98 SL2 Fuel Filter | brerrabbit23 | S-Series Tech | 2 | 08-10-2002 12:37 AM |
