Old 06-22-2019, 01:05 PM   #361
Default Re: 99 SL2 rebuild thread
The '99 rear suspension is good again. After my debacle on the '98, I was really worried about replacing the drag links. With new links, greased and anti-seized bolts, we should be good for another 20 years. I was happy with the quality of the Dorman parts.
Add to Waiex191's Reputation
Old 07-08-2019, 10:49 PM   #362
Whoops - wrong car. Over to the '98 thread.
Old 08-30-2019, 07:55 PM   #363
Check out this rotor:
What causes this? Poor quality rotors? Plenty of meat on the pads but the inside of the passenger rotor is trash.
The 3 other surfaces of the rotors are fine.
Old 08-30-2019, 08:33 PM   #364
Sticking/dragging pins usually and less than top shelf rotor material. The inside almost always looks worse that the outside even when everything is letter perfect.
Old 08-30-2019, 09:42 PM   #365
Interesting. We got new pins, boots, and used sylglide at the rebuild.
Hovercraft duct Bondo work and brakes:
We went with the same Centric brakes I used on the '98.
Old 12-01-2019, 04:36 PM   #366
The kid came home for Thanksgiving and the left front bearing sounds horrible. I think over winter break we are going to replace it. While we are in there, it is time for new control arms and a stock clutch. Which nut needs to be replaced? Is it the big nut that screws onto the driveshaft, like the one just threaded on in the picture below?
We did not replace those nuts. Would it be worth it to re-torque that nut?
Old 12-01-2019, 06:37 PM   #367
We re-torqued the nut. They were tight. Looks like new bearings are needed.
Old 12-07-2019, 01:37 PM   #368
My new control arms, bearings, and nuts came in the mail.
SKF bearings made in Spain.
Old 12-08-2019, 11:55 PM   #369
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
That is one job we have not had to do yet. I am sure my time will come.
Hope it goes well for you.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 12-12-2019, 09:41 PM   #370
Thanks Mark!
My new, stock LUK clutch came in the mail today. I'll be glad to be rid of the stage 2 clutch.
Old 12-21-2019, 01:33 PM   #371
The carnage has started. I'll have to get the livestream going.
Old 12-21-2019, 09:03 PM   #372
Torn apart:
The snap ring was rusted in. Was a bear to get off.
We set it up in the EAA 1414 press.
The inner race came apart.
I modified a 3 arm puller to grab onto a small groove in the race. That didn't work. Then I dremeled a slot into the race, with the intention of splitting the bearing. It didn't split but it did spin and move out so I could pry it off. Sorry for the blurry picture.
Old 12-21-2019, 11:34 PM   #373
chris's sc1
chris's sc1 is on a distinguished road
I havent read the whole thread but what's wrong with the stage 2 clutch. Just wondering because I wanted to get one
Add to chris's sc1's Reputation
Rate the quality of this post and help chris's sc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chris's sc1 is offline   Reply With Quote
Old 12-22-2019, 12:33 AM   #374
On initial startup, it was super grabby. When trying to do a normal engagement the whole motor would shake back and forth violently. Reverse was even worse. This was with all new factory mounts too. It took miles to wear in and the clutch engages way at the top of the travel. We have less than 20,000 miles on it and I am not sure how much longer it will last. The stage 2 clutch was the worst thing I've ever done.
Buy a stock clutch. Don't buy a stage 2.
Edit: here is the post.
http://www.saturnfans.com/forums/sho...&postcount=279
Did I mention the stage 2 clutch sucks?
Edit 2: this post in my thread by OldNuc gives links to other reference threads.
http://www.saturnfans.com/forums/sho...48&postcount=6
I read them all before I dove in. Was well worth the time.
Old 12-22-2019, 06:38 AM   #375
454cid
You only bought the bearing, not the hub too? The whole kit isn't that expensive from Rockauto.
1999 Chevy K3500
Add to 454cid's Reputation
Old 12-22-2019, 10:28 AM   #376
Yep. In hindsight I probably would have bought the kit. Mainly because the new hubs look so nice.
Old 12-24-2019, 03:11 PM   #377
Here Adam is making a tool for pressing out the old bearings. We also turned down one end to use it for installing the hubs.
This is the tool for pressing in the new bearings.
Our initial attempt was to use PVC to support the knuckle. That didn't work! Found my 3.25" Milwaukee holesaw was the perfect diameter. Tried to turn off the teeth, then tried to pare them off. Failed. Used it with the teeth.
Here is the setup in the press. The bearing let go with a bang.
Two empty knuckles.
One screwup:. On the first one we did not replace the race that was stuck on the hub before pressing out the bearing. Don't do that!
Old 12-24-2019, 05:05 PM   #378
Adam sandblasted the hubs so we can put them in an oven. We still need to get the busted ABS sensor plastic stud out of both of them.
Here is a scene from a couple days ago. Adam was pulling the car apart, Matthew was making a new hovercraft skirt with our new Singer sewing machine, and I was keeping them from killing each other.
https://youtu.be/vTVEcLWx8yk
Old 12-24-2019, 09:06 PM   #379
454cid
Will you be freezing the bearings too? I saw a video the other day where a guy put his new bearing in the freezer over night....he did not heat the knuckle.
I would really like to blast my knuckles because they are so incredibly crusty looking.
1999 Chevy K3500
Old 12-24-2019, 09:08 PM   #380
We will freeze both the knuckles and bearings. After the knuckle and bearing assembly has stabilized I can see heating them up to 150 F together.
01 SC2 Rebuild Thread Saturninin S-Series General 3 10-04-2015 08:11 AM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 08:00 PM
My Rebuild Thread Part II jswingchun S-Series Tech 21 04-23-2009 09:55 AM
My Rebuild Thread jswingchun S-Series Tech 40 02-12-2009 12:52 PM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
