Old 11-28-2019, 05:06 PM   #6341
bumpdraft
bumpdraft's Avatar
1998 SW2
Default Re: What did you do to your S-Series today...
Originally Posted by focusofheart View Post
Until it is fixed you could always use the old arm signals, unless of course, you are too young to have used them in the past.
I fixed it immediately. I wouldn’t drive that thing without it.
They only use one type of hand gesture in these parts Driver’s around here are barely able to interpret turn signals. Half of them see a blinking light on the small car ahead as a sign to start tailgating even closer — “Turn signal use is a sign of weakness. — MUST_DOMINATE
Old 12-04-2019, 10:46 PM   #6342
s-petersen
s-petersen is a jewel in the roughs-petersen is a jewel in the roughs-petersen is a jewel in the rough
2002 SL1
1994 SL2
Blinker relay, smog pump, working on EVAP sensor in gas tank
251,000 this week
1994 SL2 with 220,000, 1994 SC2 with 128,000 Both had reverse slam,SL2,fixed with nuts,SC2 needed valve body-sold,2002 SL1 251,000 needed cat, 1998 Ford Ranger 160,000 1994 SC2 166,000 parts
s-petersen is offline   Reply With Quote
Old 12-04-2019, 11:36 PM   #6343
98_Gold_Uranus
98_Gold_Uranus's Avatar
Before I left work, I removed, wet sanded, buffed, and reinstalled the 21 year old headlights on the 98.
Far from perfect still, but WORLDS better than before. SO much more light output. I can actually see a beam pattern projecting ahead of the car now instead of just a hazy glow lol
Her name is Uranus :)
Old 12-05-2019, 12:42 PM   #6344
This past weekend - cut off the old resonator / mid pipe, put high-temp POR15 over the flange and welds of the new aftermarket one, sprayed high temp paint over it, and installed
http://www.saturnfans.com/forums/sho...59#post2311259
Apparently, I've had a loud exhaust since about May based on an earlier post of mine in this thread. It's nice having a fully quiet exhaust again - didn't realize that having a loud exhaust was adding a low level of stress/anxiety to my commute.
Old 12-05-2019, 02:04 PM   #6345
Claybury
Claybury's Avatar
I haven't done this yet. Just bored today and I noticed I have some rolls of vinyl that are getting old sitting on the shelf. A quick Paint sketch latter....
I could always peal it off once I get sick of it. Think anyone would notice me coming?
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
Old 12-05-2019, 06:47 PM   #6346
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
I had been hearing a clunk, periodically, from the front end for a short time, so I did a lot of research into this forum and watched many youtubes to help me uncover the problem before it got out of hand.
I ended up lubricating the front sway bar bracket bushings, using a spray silicone, several times over two days and the clunk is gone and the problem uncovered.
I have ordered the bushing/bracket kit and since I have a 15mm socket I think I can do this myself or at least make a Chocolate Eclair Cake to bribe my hubby to help.
Saturn 1998 - SL2 automatic
Old 12-10-2019, 10:47 AM   #6347
bumpdraft
bumpdraft's Avatar
1998 SW2
98 Gold Uranus’ post (above) prompted me to fix the leak in the driver’s headlight.
First, I pressurized it and washed it with soapy water to find the leak.
After it was dry, I pulled a vacuum and applied silicone caulk.
This morning, in suggested videos, some evil, because “Internet”:
(No, I am not talking about Scotty. He was just unlucky to be next to the evil video )
Old 12-10-2019, 04:14 PM   #6348
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Put in a new wiper motor this morning. The last one I was pulled from a junkyard but this one i got from Advanced Auto for $54. It’s cheaper than what I could have gotten on RockAuto and it has a life time warranty.
I also cleaned out the 2 rubber drains while I had it apart. There was a lot of dirt packed into them. They probably weren’t doing much at all. I’ll get to fixing the vent screen someday
File Type: jpg D8B9BFD1-A363-431D-BB44-2A46726064E0.jpg (124.0 KB, 9 views)
97 SL2, auto, 121K miles
Old 12-11-2019, 11:42 AM   #6349
SLfun
2006 ION Red Line
Today I removed the ECM that I installed yesterday because the 99 ECM won't play nice with the 95 injectors I have in the motor. It was a fun task outside with the temps well below 0 this morning
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Old 12-12-2019, 01:01 PM   #6350
Pitcher
Pitcher's Avatar
Rain-X on the Windshield.
Owned 4 other S-Series.
Old 12-12-2019, 07:52 PM   #6351
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Despite replacing the sway bar, the control arms and their bushings recently, I've been hearing some clunking and groaning on the passenger side. My plan was to remove, disassemble and reassemble the strut and strut mount but in the spirit of K.I.S.S. I thought I'd try the silicone spray on the sway bar bushings first.
They are a lot quieter now, but then again, my bushings aren't quite seated properly in the sway bar bracket-- next on my list.
Goggles Pisano is offline   Reply With Quote
Old 12-13-2019, 07:14 PM   #6352
focusofheart
This was my 'clunk' that was fixed today with new sway bar bushings and brackets. Silicone grease was then applied to all bushings while the car's skirt was hiked up.
They lasted 21 years
Old 12-13-2019, 08:18 PM   #6353
Zeebins
Zeebins's Avatar
Swapped out the orange turn signal bulbs with chrome painted ones that are still amber when on. They're more red than amber imo, but they look a lot nicer when off.
Old 12-14-2019, 12:55 PM   #6354
Pitcher
Pitcher's Avatar
...skirt was hiked up.
Love it!
Old 12-14-2019, 01:54 PM   #6355
focusofheart
My shift lever was having a little problem getting out of park, so I learned what to do from this forum and grabbed a Philips, a couple different sprays and ended up taking the console off to clean and lubricate the solenoid.
So far, so good.
At least I am now aware of the 'bypass' so I can start my car when the time comes to replace the solenoid.
Thank you FORUM!!
Old 12-14-2019, 03:06 PM   #6356
454cid
My car did that just the other day.... I assumed it was snow/ice or possibly a linkage/cable going bad. I'll so a forum search and see what info I can find before it really causes me trouble.
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
454cid is online now   Reply With Quote
Old 12-20-2019, 12:42 AM   #6357
98_Gold_Uranus
Pulled the fog lights out. Going to give them a sand and buff tomorrow. While I have them out, I have another project I want to tackle with them. Have some LED fog light pods from a Jeep Wrangler that are about the same size. I want to see if I can model up some brackets to mount the LED fog lights to the factory SL2 fog light mounting brackets, then 3D print them out and see how it works out
Old 12-20-2019, 10:43 AM   #6358
98_Gold_Uranus
They came out awesome
Same process as with the headlights, started with a pneumatic orbital sander, then hit it with a coarse and fine buffing compound on a bench top buffer. Would take forever by hand, took about 5 minutes per light with powered tools
Still going to press forward with the LED light mounting bracket project though. But if that fails at least these look great again for 21 year old lights!
Old 12-20-2019, 12:49 PM   #6359
454cid
The picture links are broken.... I'd suggest something besides Photobucket since they blur most of them anyway.
1999 Chevy K3500
Old 12-20-2019, 12:56 PM   #6360
454cid
Not done to the car.... I'm impatiently waiting for my parts. Like many times I've ordered online tracking shows them arriving a day earlier than predicted.
I've got my NTK ECT sensor, and Motorad thermostat/water-neck arriving today. I'm curious to see if the Motorad is made in Germany, or China. Kinda curious to see where the ECT sensor comes from too, but more so on the thermostat since all the hub bub on the Stant being the only one that works.
I might finally get my super discount Menard's special wipers put on my truck today.... that'll get them off my desk!
1999 Chevy K3500
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
