Old 12-09-2019, 07:04 AM   #1
Jonasan308
Jonasan308's Avatar
1999 SC1
Default Your opinions on the performance switch on equipped auto S-series?
I have a few more observations and then i will be able to post my own experiences regarding the performance switch in my SL2. But just wondering what everyone elses experience has been with use of the switch for various situations.
1999 SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 SC1-156K at purchase(oct 2016)-215k(Oct 2019)
1996 SL2-116k- (oct 2019)
Old 12-09-2019, 09:01 AM   #2
onlinebiker
Default Re: Your opinions on the performance switch on equipped auto S-series?
About the same as the rear deck spoiler.....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 12-09-2019, 03:07 PM   #3
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Checkered Flag Re: Your opinions on the performance switch on equipped auto S-series?
Yes, make certain ALL passengers are using their restraints.
REMEMBER
With great power comes great responsibility
1999 SL2 A4 -86k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is online now   Reply With Quote
Old 12-09-2019, 06:50 PM   #4
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
"Don't touch Turbo Boost. Something tells me you shouldn't touch Turbo Boost."
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 12-10-2019, 01:14 AM   #5
It doesn't do much. In 'normal' mode it shifts mostly normally even at WOT (may hold a shift a few hundred RPM, but not much) while in performance mode shifts are a bit firmer and at WOT it'll hold the shift until redline. Around '95 they decided the switch was dumb and just made it hold the shift until redline while at WOT.
Neither mode makes it shift properly.
Old 12-10-2019, 10:27 AM   #6
The moral of the story is, if you want your shifting done right - do it yourself
Old 12-10-2019, 01:10 PM   #7
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
I never had use for it. I have yet to have to jump a ravine and the flames from the exhaust will melt your rear bumper cover?
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 12-10-2019, 01:28 PM   #8
I can't believe you guys didn't point this guy in the direction of the performance switch.
http://www.saturnfans.com/forums/sho...d.php?t=238486
Add to Waiex191's Reputation
Old 12-10-2019, 01:42 PM   #9
bluesl2
bluesl2's Avatar
97 was the last year it was used. The engineers did away with it because it's not needed. The PCM has an adaptive learning ability to adjust to whoever is driving the vehicle and how.
Add to bluesl2's Reputation
Auto Tranny Drip - Opinions? (pix) smeltjr S-Series Tech 3 08-22-2010 11:36 AM
Performance switch on an auto befarrer S-Series General 6 03-11-2008 11:04 AM
Getting VTi 3.5 Installed Now, Looking at 06 Vue FWD Auto, Need Opinions mikec Vue General 22 01-20-2007 05:38 PM
Timing Chain Failures In 2000-2003 Saturn L-series Vehicle Equipped With The 2.2l Cincy Saturn L-Series General 7 08-06-2006 08:58 AM
Performance switch and mpg walt S-Series General 0 04-02-2005 08:26 AM
