Old 12-05-2019, 02:43 PM   #1
Upstate Saturn
Upstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really nice
Upstate Saturn's Avatar
2001 SL2
Default Any way to make tail lights and brake lights brighter?
Is it possible to get brighter bulbs for the tail lights and brake lights? I saw a couple of threads here that didn't recommend it due to the older wiring design not working with newer bulbs, but since the threads were a few years old, I thought I'd pose the question again.
2001 SL2 manual - original owner - remanufactured engine at 228k miles, December 2015
1992 SL1 - bought used in '93, totaled in '00 at 170k miles, drove it cross-country a lot!
Add to Upstate Saturn's Reputation
Rate the quality of this post and help Upstate Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Upstate Saturn is offline   Reply With Quote
Old 12-05-2019, 02:47 PM   #2
Default Re: Any way to make tail lights and brake lights brighter?
LED's may help but you'd have to get the correct color for each position, otherwise I believe 30 series bulbs are upgrades on 10, 11 and 20 series. I believe stock bulbs are 1157, so you'd look for 3057: https://shop.advanceautoparts.com/p/...lbp2/5080916-P
I don't remember if the S-Series uses a round base or a wedge base for the bulb (the 3057 I linked to is a wedge base), verify the one you get has the correct base and correct number of filaments.
Old 12-05-2019, 10:49 PM   #3
Zeebins
Zeebins's Avatar
The S-Series uses a round base
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Zeebins is online now   Reply With Quote
Old 12-06-2019, 01:37 AM   #4
TomM96
I've had great luck with the wire harness generally, and lights on both my '97 & 2000 S cars. On the '97 i renewed the headlamps fixture because 1.) lens yellow, 2.) reflective backing corroded dull, 3.) level adjustments frozen-corroded.
Some folks have experienced leaking water into the rear light fixture. If the bulb sockets get wet, the connections can degrade due to corrosion.
Sometimes cleaning the bulbs/sockets can improve the illumination. Sometimes a thin coat of silicone dielectric can exclude moisture from clean contacts.
If wet lamps maybe try good dry ones from a wrecking yard.
I do think brighter bulbs are available-check base,voltage,lumens...
but frequently a brighter bulb will burn out sooner. There may be aircraft bulbs available for the brakes (they are illegal for headlamps.
For the 'upper' brake light array, red LEDs would probably be better because they create less heat (use less power).
Add to TomM96's Reputation
Old 12-07-2019, 01:57 AM   #5
Interesting thread. I believe wiring for 3rd gen Saturns is improved over original first gen to correct original weaknesses. With that in mind, if there were any issues with 3rd gen lighting/wiring issues, there should be threads about them. Presuming there aren't any, I would tend to think if brighter brake lights are considered then some factors should be considered if brighter lamps can fit; lens body accommodating any extra heat, sockets relatively free of severe corrosion preventing good electrical flow, and other things.
At the least, start with the basics - what wattages are used in original brake lights. Using the 1157 round base images, the card indicates two wattages - 26.9w and 8.3w. I presume 26.9w for brake lighting, 8.3w for rear running light. I would use these two wattages as baseline values when looking for brighter lamps with assumptions of higher wattage interpreted as brighter lighting. Be aware that led lamps may mislead by conveniently leaving out any references to wattage and use lumens. Equivalent wattage is one misleading method while lumens is more accurate. The problem is converting wattage to lumens and vice versa to find compatible lamps meeting original wattage then finding brighter lamps to achieve your goal of brighter brake lights. I mention this because of a similar issue when attempting to replace dome lights with leds.
In my case, I have three dome lights; two for right or left rear passenger use and the main dome light for general lighting. I bought three leds and found they didn't improve on lighting. My mistake was assuming replacement leds would be plug 'n play and brighter when they were actually dimmer than expected. I kept the two rear leds but returned the main led as it was lower in equivalent wattage then the original. Some things don't work despite good intentions.
It's a little unusual for anyone to ask for brighter rear brake lights when the tendency is to darken/smoke the red lens and replace lamps for leds. This tends to have a two fold effect of lowering brake lighting. While no one has reported being stopped for dimmed rear lighting, this may be a safety issue as far as warning the rear driver about braking at night when these smoked lenses and led conversions dim DOT standards for rear illumination. As always, its a personal choice.
Old 12-07-2019, 05:16 AM   #6
Forgot to include this image.....
Old 12-07-2019, 07:52 AM   #7
me.theuser
2002 SL1
2001 SL2
My 3rd gens both use the wedge style bulbs
in my 2001 I have LL 3157
https://www.sylvania-automotive.com/...7_longlife.jsp
in my 2002 I decided to try out the Sylvania ZEVO Super Bright 3157R
https://www.sylvania-automotive.com/.../3157_zevo.jsp
They are brighter but not that much brighter TBH especially not bright enough to justify the $20 price tag
Add to me.theuser's Reputation
Rate the quality of this post and help me.theuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-07-2019, 06:54 PM   #8
$20!? They're $8 for 2 at the 50-100% overpriced FLAPS! lmao (they're under $4 on Amazon...)
Old 12-07-2019, 07:16 PM   #9
Zeebins
Zeebins's Avatar
]in my 2002 I decided to try out the Sylvania ZEVO Super Bright 3157R
An LED is usually only brighter if you use a color that matches the lenses. Red for brake light, amber for turn signal...
Powered by Plastic
Old 12-07-2019, 09:24 PM   #10
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
I have replaced the dome, side lights, trunk, and backup lights with LEDís...
https://www.superbrightleds.com/
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 12-08-2019, 01:02 PM   #11
me.theuser
2002 SL1
2001 SL2
The ZEVO 3157R is the red version, main issue is that the LEDs point towards the reflector and the Saturn reflectors are silver spray paint rather than real reflectors
fetchitfido maybe your FLAPS and Amazon are different than mine??
Old 12-08-2019, 03:35 PM   #12
Yes there is and there above that will really do the job either.
eBay item number:
392454597802
Once you get into these you will see many different LED drivers for multifunction use. The rear body support tends to kick-up slightly from the wheel suspension back to the bumper shield enough to hide a pair of these wired as white lights an placed inboard of the rear tires on that rear structure and still not get scraped off. The really do fix the backup light problem. All the put a better bulb in it fail from either heat, useless housing design or both. This will work and there may actually be a couple of holes that make this a bolt on and they will not overload existing Saturn backup light wimpy wiring. They are also usually lower cost.
No tail lights, dash lights, auto headlights but have brake lights Troubled Saturn L-Series Tech 2 12-23-2015 07:11 PM
No tail lights/brake lights on my 99 SL1 Liriodendron S-Series Tech 1 05-06-2014 01:57 PM
clear tail lights and black tail lights on ebay cheap ericblkredline Vue Mods 5 08-28-2008 03:08 PM
Tail lights yes, brake lights no? yiimmy S-Series Tech 10 04-06-2007 09:08 PM
