Old 12-05-2019, 06:08 PM   #1
fjordman1995
fjordman1995 is on a distinguished road
1993 SL2
1996 SC1
Default Rear drum backing plate swap (what years fit)
Need to replace the drum backing plates on 1995 sc1. Anyone know what years will fit?
Thanks,
Warren
fjordman1995 is offline   Reply With Quote
Old 12-05-2019, 10:51 PM   #2
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Default Re: Rear drum backing plate swap (what years fit)
Any S-Series from 93-02 will work. IIRC, 91-92 Did't Have the option for rear discs.
EDIT: Totally miss read your post, thought you where converting to discs and needed the dust shield. Any year should work, 91-02
97 SL2, auto, 122K miles
Old 12-06-2019, 01:41 AM   #3
TomM96
Maybe consider replacing the entire rear suspension with one from a wrecking yard which happens to have Way Less rust... might save maintenance time in future.
I have dutifully renewed backing plates on other vehicles... but maybe another option.
Old 12-08-2019, 10:20 AM   #4
fjordman1995
1993 SL2
1996 SC1
Thanks for the info, anyone know if that is in the swap guide? Or is there a way to search JUST the swap guide thread?
Took the plates off the spare (collision rearranged) 1996 sc1, they were better but still 3-5 out of 10 and blasted and will repopulate the missing metal por 15 for now (before/after pix to follow) if anyone's interested
Warren
Old 12-08-2019, 11:34 AM   #5
Waiex191
Waiex191's Avatar
I know of no way to search one thread. Of course we are interested - this sort of thing is why we are here! Backing plates on my '98 are trash.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 12-08-2019, 11:44 AM   #6
IIRC the backing plates are sandwiched between the bolt-on rear wheel bearing and the knuckle...as long as the undersized 10mm hex-head bolts (heads should be at least 12mm for the torque required) come out fine it should be a super simple swap.
They should also be the same '91-'02 so whatever you find in rust-free condition should swap on fine.
Old 12-09-2019, 09:16 AM   #7
trottida
trottida's Avatar
At the top right of this thread in the column header there is a search this thread option. I have no idea if it works though.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
trottida is online now   Reply With Quote
Old 12-09-2019, 01:55 PM   #8
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
It works I use it often
Mark_b is offline   Reply With Quote
Old 06-28-2020, 08:27 PM   #9
RodRy
RodRy is on a distinguished road
1996 SC1
IF anyone finds a good set, let's get them 3D scanned and generate files to have them remade. That could help everyone here in the long run.
RodRy is offline   Reply With Quote
Old 06-28-2020, 09:52 PM   #10
billr
Do you have an economical way to make them from a CAD file?
Old 06-29-2020, 07:40 AM   #11
454cid
I re-used mine, even though I thought they needed to be replaced. Each one is/was quite crusty, and one of them has additional ventilation. Both are bent up a bit from hammering them off the car....after being wire wheeled as best as I could, I then soaked them in Evaposrust (which didn't do as much as I had hoped) and then primed/painted them, and reassembled with anti-seize.
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
Drum Brake Backing Plate NLA? DoriftuEvo S-Series Tech 1 09-27-2016 09:10 AM
L200 Rear disc conversion. (or a new Left drum backing plate ) DakRatFink L-Series Tech 8 03-12-2014 09:12 PM
Bent drum brake backing plate (I'm an idiot) jzambon S-Series General 6 02-18-2014 07:22 PM
Need rear drum backing plates for 94 SL2 Ray Dog S-Series Tech 7 06-20-2012 09:26 PM
Rear disc swap, removing drum assembly. FenderGuitars77 S-Series Tech 0 05-01-2011 03:06 PM
