Old 12-04-2019, 10:30 PM   #1
chris's sc1
chris's sc1 is on a distinguished road
Default Rebuilding 96 dohc
I'm in the process of doing a rebuild. And I'm going to clean parts while the block and crank are at the machine shop.
My first question. Can I soak the pistons with out removing the wrist pins.
Add to chris's sc1's Reputation
Rate the quality of this post and help chris's sc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chris's sc1 is offline   Reply With Quote
Old 12-05-2019, 09:30 AM   #2
onlinebiker
Default Re: Rebuilding 96 dohc
Sure.
You can also shower in a raincoat...
But do you think that's really the best way to get cleaned up?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 12-05-2019, 09:33 PM   #3
chris's sc1
Starting the piston soak. Measured side ring clearance before removing the rings. I dont have to buy new pistons. I'll be pulling these out in 4 hrs.
Old 12-05-2019, 10:30 PM   #4
Nice! Are you going to drill holes in the oil control ring slot?
Edit: new pistons are nice too.
Add to Waiex191's Reputation
Old 12-05-2019, 10:48 PM   #5
chris's sc1
I wasnt aware that was an upgrade or mod. What does drill the holes do for it
Old 12-06-2019, 08:54 AM   #6
Chris,
Do a little searching on the forum. The short of it is the oil is able to drain back into the engine rather than coking up an immobilizing the rings. That is what causes saturns to use oil. You will notice my aftermarket pistons have slots for that in the oil ring. If you have a V block and a drill press it should not be a hard job.
Edit: one thread that has a YouTube link.
http://www.saturnfans.com/forums/sho...d.php?t=223094
Edit 2: my search.
https://www.google.com/search?q=site...obile&ie=UTF-8
Old 12-06-2019, 10:14 AM   #7
chris's sc1
Yes I will be drilling those holes. I watched a YouTube video on it so now I'm up to date on that info. Thanks for sharing.
My pistons are not yet clean. I starting soaking them in berrymans chem dip last night at 6:10 utah time. My chem dip might be a worn out by now I have used it a lot. If they aren't clean by the time I get home today I'll have to get another gallon.
Unless there is another way besides wire wheel.
Old 12-06-2019, 11:19 AM   #8
You'll have to do a search but I think DIYguy cleaned his while they were out of the engine, using household ammonia. May have left it out in the sun to heat up.
Somebody else (cboss? ehunter?) said that soaking in ATF softened the carbon considerably
Old 12-06-2019, 08:29 PM   #9
chris's sc1
Thanks for the tip. I just walked in. And havent checked them yet. But I'll update here shortly
Old 12-06-2019, 09:04 PM   #10
I think Lowe's Depot still sells MEK. Besides being death on a Ritz, it is a very good solvent.
Old 12-06-2019, 10:30 PM   #11
chris's sc1
Adding heat did the trick. Softened it right up. Only took an hr or so. But they are clean. I've got a friend who has a drill press that can drill the oil holes for me. I'll post some pics of them when they are done.
Old 12-07-2019, 11:29 AM   #12
Looks like HomeDepot has gone the way of California.
No MEK, but been replaced with Klean-Strip (not as volatile).
But, Walmart of all places sells it by the gallon.($39).
https://www.walmart.com/ip/Methyl-Et...CABEgLS-fD_BwE
Old 12-07-2019, 01:50 PM   #13
onlinebiker
Our local TruValue hardware (Bob's in Otsego) still carries it. $26 a gallon if memory serves...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 12-07-2019, 01:54 PM   #14
454cid
Klean Strip is a brand/company.
1999 Chevy K3500
Add to 454cid's Reputation
Old 12-08-2019, 01:09 AM   #15
chris's sc1
All is good, pistons are clean and are ready to go get the oil holes drilled. Going off the YouTube video. 3 holes on each side should be plenty right.
Is there anything special I need to have the machine shop do to the crank and block.
The crank bearings were completely shot but the surface of the crank looks good to resurface. The cylinders look like they are good. the cross hatching is still there with very little up and down marks. I cant feel any differences in shape where the pistons reach tdc. So I dont think the cylinders need to be bored. Maybe just power honed to take the glaze off and redo the cross hatching. Decking the block, I'm going to have them do that just because I want it to have a true surface.
Let me know if theres anything else. Thx
Old 12-08-2019, 11:29 AM   #16
Three holes per side is way better than zero. Seems good to me.
My machine shop evaluated my crank, bore, deck, and head. My crank was not turned down, I just got new bearings. My bores had taper and were bored up one size. I can't remember them doing anything to the deck but they skimmed a couple thou off the head to make it flat. Maybe they cleaned up the deck? Don't take off much at all though.
Here is the before picture.
Old 12-08-2019, 11:40 PM   #17
chris's sc1
Before pic of the deck and after math of cleaning the pistons. Using berrymans chem dip. Heating it up works wonders. I'll post more pics when I get the piston oil holes drilled out
Old 12-09-2019, 07:29 AM   #18
Here was the inside of my bores before.
Old 12-09-2019, 09:42 AM   #19
chris's sc1
Yeah those dont look near as bad as mine. The person I got the car from beat it pretty hard. The roll pin in the trans was broken so the trans was no good.
Old 12-24-2019, 11:23 PM   #20
chris's sc1
Ok guys the block is at the machine shop. I'm having it decked just so the surface is true. Cleaned and honed. He said the cylinder walls look good enough to just do a power hone without over sizing.
What the best ring set I can buy. I'm going to turbo this motor and want to get good rings.
Rebuilding 95 DOHC SC2 RichBrown S-Series Tech 374 07-15-2015 01:47 AM
'93 DOHC Engine - 3 Rebuilding Questions carlbo S-Series Tech 0 08-13-2012 03:12 AM
Rebuilding 1.9 dohc with my daughter. Joel65 S-Series General 10 02-14-2009 01:46 PM
rebuilding 1.9l dohc, piston question dsbike S-Series Tech 5 06-12-2008 09:06 PM
Rebuilding a DOHC???? tjd83 S-Series Tech 3 02-10-2007 09:51 PM
