Old 11-26-2019, 12:40 PM   #101
cantom
cantom is a jewel in the roughcantom is a jewel in the roughcantom is a jewel in the rough
Default Re: Well darn, my '99 SL2 laps oil like a BMW
If the valve cover itself is warped and was not replaced, a new gasket could temporarily fix the issue only for it to appear again, or the cover could have warped. Checking is free and easy, takes a few seconds (use clean paper towel to wipe area, should be dry).
It's common / normal to rule out new parts or things that were recently serviced, but search around and you will see that sometimes the new part was faulty out of the box. My approach to troubleshooting is usually start with the cheapest methods / likeliest things
I don't know how rapidly you are losing oil, but a drop of oil every few hours may not leave a pool or puddle but over the course of a week can add up, especially when added to the normal oil-burning you get from driving highway speeds.
That's good news.
Is it the original OEM PCV valve, and does it rattle when shaken? I've never had a problem (replaced the PCV with a fixed orifice one in my 98) but some threads have shown the PCV to occasionally be the cause of inexplicable oil burring. A few folks have said that the current PCV valves sold will fit but have a wrong spring rate or something.
Okay. It is the valve cover gasket. Leaking like a good thing. I paid to get it done a year ago but will not be going back there again. They also used a fair bit of black RTV...a very sloppy job. I hope they even put a new gasket in.
I just watched a video on youtube on replacing the gasket and 2 grommets. Simple enough but...did I read on here that the OEM covers warp and cause leaking?
Someone suggested getting the cast cover from an earlier Saturn because it's less likely to warp?
This is a 2001 SL1 SOHC.
Likely that I need to source a different cover?
I wonder if someone has one of the good covers they'd sell and ship reasonably?
PCV valve rattles and is like new.
Add to cantom's Reputation
Rate the quality of this post and help cantom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cantom is offline   Reply With Quote
Old 11-26-2019, 12:55 PM   #102
trottida
trottida's Avatar
I see you specified SOHC (2001 SL1).
I believe the warped covers affect only the DOHC engine and specifically 95-98 (maybe 94) where they were made of composite rather than aluminum. You can put an aluminum from an earlier model on to resolve. The 99-02 DOHC used composite as well an you cannot use an earlier model as the head changed to the narrow head. If I recall they aren't an issue like the 95-98's as far as warping goes.
The SOHC on the other hand had aluminum valve covers throughout its entire run 91-02.
<< you may want to update your profile to add the 2001 SL1 so others don't think you are talking about the 99 SL2. Look in the left sidebar of your posts.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-27-2019, 12:38 PM   #103
This is a how to written by a (at the time) trained Saturn tech
http://www.saturnfans.com/forums/showthread.php?t=26532
At one point, apparently there was no gasket for SOHC engines and they used RTV only, but since then a gasket became available.
Instead of Brake Kleen, I'd use something that member OldNuc recommended - plain acetone ($3 or so at Walmart, in the nail polish section - make sure is unscented, no stuff added, etc) for cleaning the surfaces
Aluminum, as trottida mentioned. Although it will not warp, if there is a chance it has been dropped or something, you can place it on a perfectly flat surface and move it around, looking for gaps in contact
Note that several people say that the book spec for torque is too tight (resulting in snapped bolts) and suggest a lower value
http://www.saturnfans.com/forums/sho...d.php?t=222157
edit: I've also never washed the inside of the covers when doing this. I guess I am not that particular, or my covers weren't that dirty? Though wiping / scraping off big chunks isn't a bad idea
Old 11-30-2019, 03:15 PM   #104
cantom
Ah, okay, originally no gasket?
At any rate, apparently using a Fel Pro blue gasket, the job was done yesterday by my local shop and I see no sign of leaking. Maybe I can stop adding oil now...I hope.
2001 SL1 SOHC
Canada
Old 12-02-2019, 09:57 AM   #105
Correct, from what I have read - no gasket originally. But apparently, removing the cam cover was a real PITA because of the RTV - involving razors, prying, hoping nothing cracks, and cussing.
Good news that it seems to have fixed the worse leak, thanks for the followup. Keep an eye on the oil level, though - AFAIK, I have no leaks and I am adding 6~9 oz of oil a week (about 250 miles hwy) to keep it slightly above the FULL mark on the dipstick
Old 12-02-2019, 03:22 PM   #106
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
You are filling to just above FULL or just above the hashmarks?
1999 SL2 A4 -86k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 12-02-2019, 03:53 PM   #107
Whoops, I phrased that poorly. Just above the hashmarks, around the "U" in the word FULL
By the time I check the next week, I am usually back down to the top of the hashmarks, maybe one diamond below
Not my pic, but this is what I am calling the FULL mark
Old 12-02-2019, 05:13 PM   #108
NWSaturn247
Thank you for the clarification. For the record, I often topped off my oil to FULL on my '93. Did not seem to be an issue to the day I sold it at 189k miles
The first person to see and test drive it, purchased it
She drove it quite aggressively putting the car through a torture test. SOLD LOL
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 12-02-2019, 07:40 PM   #109
Pitcher
Pitcher's Avatar
I always fill to the "U" or 1st "L" of FULL on all 4 of
my S-Series for the past several years. Zero issues.
BTW I can hear when it's down to the 2nd or 3rd
crosshatch; engine sounds slightly more "raw".
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Darn it, Saturn, you've done it again :) dulino Vue General 5 11-12-2007 01:42 PM
cant get the darn air box out !! blazer Ion Mods 8 08-06-2007 11:32 PM
Texas Motor Speedway Laps for Charity Dante Events 0 05-09-2006 09:50 PM
Vue Red Line doing laps at the TX Motor Speedway Dante Vue Red Line 9 11-08-2004 03:49 PM
Darn cat SpiderWebb Ion General 23 01-23-2004 05:38 PM
