Old 05-18-2008, 03:31 PM   #1
cris_thomas
cris_thomas is on a distinguished road
cris_thomas's Avatar
Default Help diagnosing suspension/steering problem.
2001 Saturn SC2 Manual 167,000 PS No ABS
Severe Bump steer when going over bumps. Steering wheel will actually move in hands. Worse when cornering and turning.
No unusual noises when turning. Original struts. There doesn't seem to be any play in the wheels. I jacked it up and tried to see if there was any play in the front wheels but everything seems to be pretty solid. I recently replaced the outer tie rod ends and that seemed to help for a day or two but now it is worse than ever.
What are the odds that I just need new struts? How can I tell for sure that it isn't something more serious like the LCA or something in the steering linkage? Thanks.
- Cris Thomas
SPOC New England
http://www.spocne.org
Add to cris_thomas's Reputation
Rate the quality of this post and help cris_thomas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cris_thomas is offline   Reply With Quote
Old 05-18-2008, 03:46 PM   #2
keith122
keith122 is on a distinguished road
Default Re: Help diagnosing suspension/steering problem.
I had the same problem with my SL2. It bounced all over the road when you hit a bump. I installed out tie rod ends, which did help some. I was going to install inner tie rod ends, but the cost of the ends, and the needed tools to install them, was almost as much as a re-man rack. I ended up buying a used rack for $40.00, installed that and now it drives just fine. I did it in the driveway. Not a big deal really....especially if it's a manual rack.
Keith
Add to keith122's Reputation
Rate the quality of this post and help keith122 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keith122 is offline   Reply With Quote
Old 05-18-2008, 03:48 PM   #3
Kappa24
Kappa24 is on a distinguished road
Kappa24's Avatar
with 167,000 miles on the OEM struts....i'd venture to say that they are probably NOT helping the situation
'99 XJ Classic w/ a TON of mods...
Add to Kappa24's Reputation
Rate the quality of this post and help Kappa24 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kappa24 is offline   Reply With Quote
Old 05-18-2008, 04:33 PM   #4
BarnOwl
BarnOwl's Avatar
2000 SW2
cris_thomas let me first say that I found your guide very helpful when it came time to do a clutch.
For lack of a better thing to say. I'm going to say inner tie rod ends. You can borrow the tool to do them at Advance or Autozone. I've never ran across a bad one. So, I could easily be wrong. Here's a quote from a site I found about them
Inner Tie Rod End: Symptoms of bad inner tie rod ends include looseness of steering, severe torque steer, and a "clunk" at full or near full-lock parking lot maneuvers. Inner tie rod end symptoms are worse when the car is loaded with people and luggage. Those who've commented on the condition of the inner tie rod ends have stated that the end was lacking in lubrication, suggesting that the factory either had not lubricated the end or that the end had at some point dried out.
Inner tie rod end wear is more difficult to detect than is outer tie rod end wear. The best way to check the tie rods is to remove the ends from the steering knuckles and push/pull on them towards the steering rack to check for wear. Helm's states that the inner tie rod end should have around 10 lbs. of resistance with the outer tie rod end disconnected.
Use your own judgement and thanks again for the guide.
Add to BarnOwl's Reputation
Old 05-19-2008, 01:05 AM   #5
madpogue
1996 SW2
At 167,000 miles, I'd also look carefully at the strut-top mounts. Open the hood and bounce the car on the suspension while observing the mounts. If you see any movement between the "layers" of the mount, stick a fork in it, it's done. If you're also doing struts, it's zero extra labor.
Add to madpogue's Reputation
Old 05-19-2008, 10:05 AM   #6
cris_thomas
The struts and upper strut mounts will definitely be replaced. Probably this weekend. However, I'd rather not take the suspension apart twice or have to get more than one alignment.
Is there any way to check the status of the Lower Control Arm, inner tie rod ends, or anything else that might cause the bump steer without taking the whole thing apart?
- Cris Thomas
SPOC New England
Old 07-21-2011, 10:42 PM   #7
prioris
prioris is a jewel in the roughprioris is a jewel in the roughprioris is a jewel in the rough
My original struts (on 1999 saturn sl1) were pretty shot at over 210K and that was mostly highway driving. They should have been replaced long before that. my struts didn't feel that bad either. no excess bouncing although ride became subtly more fatigue. when they were taken off, and i pushed down on them, the struts did not spring back up.
At 167K, i would be looking at condition of the struts if they have that much mileage.
my rear brakes were worn down to thin metal also. the brake drum had to be taken off to see that. just recently, i think the bad struts i replaced before the struts caused a newly installed control arm to go bad.
oops, i didn't see the date ... couple years old ... oh well
Add to prioris's Reputation
Rate the quality of this post and help prioris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
prioris is offline   Reply With Quote
Suspension/steering swap ??? mgordon1100 S-Series Tech 0 03-02-2009 10:58 PM
Need Help on diagnosing problem caterpillar S-Series Tech 9 12-24-2007 11:54 AM
Need Help Diagnosing a '95 SL2 Clutch Problem Bob K S-Series General 19 11-24-2007 11:54 AM
96 SC2 Need Help Diagnosing Problem Matt_Fontenot S-Series Tech 4 03-16-2007 09:53 PM
Steering and suspension problems L100 L-Series General 1 09-18-2003 09:49 PM
