Old 09-03-2007, 08:28 PM   #1
casterman
casterman is on a distinguished road
Default 94 SL2 Automatic shifts hard
have a 94 SL2 automatic with 87,000 miles -- every time it shifts from 1st to 2nd and then from 2nd to 3rd it bangs pretty hard and will chirp the tires if you are in the throttle -- I have a car lot and bought the car at auction so I do not know much history -- it is not terrible but it does get your attention. Anyone have any experience with a fix in a can? Trans Medic or Lucas? or just a waste of time and money?
casterman is offline   Reply With Quote
Old 09-03-2007, 08:32 PM   #2
1994Saturn
1994Saturn will become famous soon enough
1994Saturn's Avatar
1994 SL2
1994 SL1
Happy Re: 94 SL2 Automatic shifts hard
Most will say don't use Transmission addatives...
I must ask.. how is the trans fluid? Did you change the fluid when you got the car home?
Very easy to do.. Easer then a oil changed. Get a OEM transmission filter from Saturn, and 5 or 6 qts of Mobil 1 Full Syn Trans fluid.... Will probability make a word of difference.
Current:
1998 SL2 Auto issues 112K
1995 Eagle Vision 3.5L TSI 117K
Past:
98 SL1 254k miles Valves Burnt.
94 SL2 125K miles Diff Pin Blew!
94 SL1 Sold @134K.
1994Saturn is offline   Reply With Quote
Old 09-03-2007, 09:08 PM   #3
gignac02
gignac02 is on a distinguished road
Default Re: 94 SL2 Automatic shifts hard
I had this problem on my 93 saturn a few years ago. Pull up de plug on tranny cover, you will find ten pins, check resistance between thems, each 2 pins are hook to a selenoid valve, resistance sould be 3 to 8 ohms. One of them is probably a lot higher. It is a easy job to replace one of those selenoid valve!
gignac02 is offline   Reply With Quote
Old 09-03-2007, 09:20 PM   #4
casterman
are you referring to an electrical plug on the outside of the tranny? are the pairs of wires easy to determine?
Old 09-03-2007, 10:00 PM   #5
deadmeat3344
deadmeat3344 is on a distinguished road
1991 SL2
make sure the switch next to he shifter is in "normal mode"
Saturns are slow
deadmeat3344 is offline   Reply With Quote
Old 09-03-2007, 10:13 PM   #6
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
Try rolling back in reverse, switching it to drive and going forward immediately. Tell us if it slams when you do that.
1999greenSL2 is offline   Reply With Quote
Old 09-05-2007, 04:07 PM   #7
gignac02
The plug is on the cover on top of transmission, need a 9mm box . the pair are easy to figure-out, first is the 2 pins toward front of car. the others are 2 pair on ech sides . ex: second and third on left front, 4 and 5 on same side. right side is same. easy to figure with an hometer.
Old 09-05-2007, 08:34 PM   #8
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
The trans uses data from the T P S,and MAP sensor ,for shift harshness/feel
also if the battery has been replaced ,the perimiters may need time to re-learn
there are several steps in sequence that have to be followed to quickly
return the perimiters to the P C M .
check all the connectors on the trans for corosion ,oil,fluid ect.
just driving normally for a few days could allow the perimiters to re-learn.
Have A Great Day , it is YOUR choice !
Dr B is offline   Reply With Quote
Old 09-05-2007, 10:50 PM   #9
sparkynsmoke
sparkynsmoke is on a distinguished road
sparkynsmoke's Avatar
2005 RELAY-2
I have a 95 SL2 automatic and my tranny's been doing the same thing with the hard shifting. My service engine light went on, the car wasn't shifting from 2nd to 3rd and would rev high to allow the car to get up to speed. I just replaced the radiator and the tranny went the next day.
Could this have been the result of the radiator? I have a code reader and it says there's no 2,3,4 gears and there's a loose connection between the spped control switch and the tranny.
I had the orig tranny "replaced" (wasn't told where it came from), or if it was my orig rebuilt, in 2003. I was wondering if maybe the tranny filter could be clogged and because of the radiator prob, the tranny fluid got burned. Please PM me with any responses. Sparky's the only car I have and right now I've been relegated to driving my dad's 81 Ford Club Wagon van (it's a big and bulky gas eater, but it's getting me around). Thanks.
1995 SL2 - Sparky- (234K+)
1997 SW2 - Smoke- (64,817) RIP my little boy
2004 Chevy Cavalier - Gordy- (103K+)
2005 Relay 2 - Swoop or Smoke II- (48K+)
sparkynsmoke is offline   Reply With Quote
Old 09-05-2007, 11:07 PM   #10
casterman
special thanks to all that responded -- here is what I have learned -- sometimes it makes you look foolish if you don't check the obvious before you panic -- YES the switch was in the Performance position instead of the Normal position, as soon as I switched it - the shifting became normal -- and, yes the battery had been out of the car for several days and I had just put a new one in earlier that day and hadn't driven it more than 50 feet before complaining about the harshness of the shifts -- thanks again
Old 09-05-2007, 11:45 PM   #11
1999greenSL2
How much are you selling it for?
Old 09-06-2007, 12:14 AM   #12
deadmeat3344
1991 SL2
im god
Saturns are slow
Old 09-06-2007, 08:57 PM   #13
casterman
all hail to deadmeat3344 -- master of obvious advice -- thanks again
got it setting out by the street with $1399 on the windshield -- really takes $1250 to buy it -- dark blue with tan leather (couple small bad places in the leather stitches) -- has light to medium hail damage on hood and roof -- has an internal rattle in the catalytic converter or muffler that I will get fixed -- good tires -- drivers side seat belt track is kaput, may get one at the "pull-a-part"
I also have a 1999 SC2 - red - 5 speed - 127K - sun roof -- nice nice car for $2650
Tulsa Oklahoma -- you can email me at casterman1@sbcglobal.net
Old 09-07-2007, 12:52 AM   #14
sparkynsmoke
2005 RELAY-2
Can anyone tell me what the "Performance/Normal" switch is on the car? I have zero clue what it is, have asked the dealer and they've told me it's like an overdrive. (Like 5th gear in a stick). My tranny, according to the code reader says no 2,3,4 gear and there's a loose connection to the speed control switch. (?) Any help would be appreciated.
Old 09-08-2007, 09:44 AM   #15
tommyhawk13
tommyhawk13 is on a distinguished road
1995 SW2
The performance switch makes your car act like Casterman's.
It lets the revs get higher for more power, and it shifts the gears faster, with less slipping. Even though the car feels like it's going to fall apart, it's actually better for the clutch bands, because there's less slipping. Think of it as a built in shift kit that you can turn on and aff while driving.
It is nothing like overdrive. OD is for lowering the revs to save gas, this switch does the opposite.
tommyhawk13 is offline   Reply With Quote
Old 09-12-2007, 10:04 PM   #16
sparkynsmoke
2005 RELAY-2
Hey all, the vehicle speed sensor was changed on Sparky and while she still shifts hard, I think I'll just have to change the tranny filter and fluid, and she'll be good to go. 13 model years old and while some have told me to get a newer car, I love Sparky and she's been very reliable.
SL2 shifts hard JohnASmith S-Series Tech 21 04-28-2014 03:06 PM
1994 SL2/shifts hard in 2nd and 3rd xtra2b S-Series Tech 0 04-06-2008 06:19 PM
98 SL2 Automatic Hard to shift when cold jpoell01 S-Series Tech 3 12-01-2006 03:32 AM
95 SL2 Automatic with Hard Shifting col_j1955 S-Series General 11 05-18-2005 06:52 PM
Ion Automatic transmission shifts hard john11v35 Ion General 5 03-20-2005 03:06 PM
