Old 05-16-2019, 02:52 PM   #61
trottida
trottida's Avatar
Default Re: Bolt on hood struts
The McMaster part number CAD info shows only 2 mounting holes and it and the redline part may actually be identical and are functionally identical for sure.
I didn't find that drawing earlier but here it is. It shows 3 holes at the top right. Does look to be the same with the exception of the ball position. McMaster seems to be more outwards at .83" than the RedLine shown in the photo following the McMaster drawing.
This is the photo of the RedLine product; they don't show a measurement for the protrusion of the 10mm ball however by eyeball it seems to be less.
File Type: gif 9512k950_ball stud mounting bracket for gas springl.gif (29.8 KB, 8 views)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 05-16-2019, 05:38 PM   #62
I dont think it is critical but you have to add 5mm to the measured value i posted as I measured to the ball centerline to a bit less than the absolute botom as the hood insulation edge is also there. 5mm is a bit less than 0.04" so that .5 + .04 = .54 + a small amount for the casual measurement. Redline may have changed the mount as the one I have is rather old.
Bolt Fairy Strikes! Timing cover middle bolt size? alordofchaos S-Series Tech 8 08-04-2009 11:58 PM
DIY Article: Hydraulic Hood Struts - Replaces Hood Prop Rod Robman L-Series Tech 4 11-09-2008 03:50 PM
Hood Adjustment Struts cam Ion General 0 03-04-2008 02:53 PM
Hood Struts TheGuy S-Series Mods 13 10-18-2006 12:38 PM
Redline Tuning Hood Struts Group Buy at redlineforums.com! handyjoe Ion Red Line 5 08-22-2006 07:29 AM
