Old 06-17-2019, 01:12 PM   #1
mstanhope
mstanhope is on a distinguished road
2003 L-Series 2.2L Sedan
Default 05 Ion3 Transmission Issues
I am totally stumped here and have no clue where to proceed from here.
I am working on a 2005 Ion3 2.2 with the VTi transmission in it. We purchased this car from one of our customers because he bought a new 18 Trax and didn't want it anymore.
When we got it, we had a few little things that were acting up like the message center saying Service Vehicle when there are no codes in the BCM, stuff like that. Nothing serious. Car runs perfectly, only has 120k miles on it and its loaded.
It sat at my garage for a week or so before I had a chance to mess with it, and immediately we found the Service Engine light on, and the transmission felt like it was slipping. Found out we have one of the Ion's with the VTi transmission in it and started to suspect that it was the problem. Only problem is that sometimes we could start the car, put it in drive, and take off like normal, then it would drop into Limp mode more or less.
Checking out the engine light, found codes P1779 and P1781 stored in the TCM. Cleared codes, and they come right back. Swapped out the ECM and the codes remained. Telling me
-P1779 Torque Delivered Signal
-P1781 Engine Torque Signal Circuit
So now i'm at my wits end about this car. Should I consider replacing the TCM instead of the ECM? Everything seems to be working just fine otherwise. I have no codes in any other system except the ABS for a bad wheel sensor which is totally unrelated.
I appreciate any help anyone can offer me.
Michael A. Stanhope
ASE Certified Technician
2004 Saturn Vue FWD 2.2 5-speed
2003 Saturn L200 2.2/Automatic
2001 Chevrolet Silverado 1500 (For towing in the parts cars!)
Add to mstanhope's Reputation
Rate the quality of this post and help mstanhope reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mstanhope is offline   Reply With Quote
Old 06-17-2019, 03:55 PM   #2
Default Re: 05 Ion3 Transmission Issues
If you have access to service manuals, you'll need it. VTI xmissions are hit our miss. A better reader is needed to decode errors unrelated to emissions. Snapon, GMs scantool, etc. My guess is the VTI xmission is the problem as Saturn Vues using this cvt ate rarely on the road, having failed early and disappearing. Some here converted theirs into auto or manuals with some degree of success.
Old 06-17-2019, 06:41 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
We first need to figure out what you really have. The VTi/CVT transmission wasn't installed in any 2005 Ions. The VTi was only installed in 2003-2004 quad coupes and it's use was stopped midway through the 2004 model year. All 2003-2004 automatic sedans have the Aisin AF23 5-speed. All 2005-2007 automatic Ions have the 4T45E 4-speed.
2007 Ion 2 Quad Coupe 5-speed manual 181K miles
2007 Chevy Equinox LT 192K miles
2018 Chrysler Pacifica Touring L 31K miles
Add to ruley73's Reputation
Old 06-19-2019, 02:47 PM   #4
mstanhope
You are right. It isn't a VTi it appears to be an Aisin 5-speed automatic. It is actually a 2004 model from what I found although the VIN reads as an 05. Must have been a left over car that was revinned.
Hopefully that helps a little. I did replace the TCM and that had no affect on the problem. The same 2 codes are still present.
Michael A. Stanhope
Old 06-19-2019, 03:00 PM   #5
mstanhope
I do not have access to service manuals. I am using an Autel Maxisys scanner which does more than most scanners do.
This doesn't have a VTi transmission as we found out, it has an Aisin 5-speed automatic in it.
Michael A. Stanhope
Old 06-19-2019, 05:16 PM   #6
'04 Ions have either VTI or 5-speed auto.
SL1 transmission issues giacom S-Series Tech 16 08-08-2018 01:55 PM
sc2 transmission issues SaturnChick95 S-Series General 12 02-25-2015 01:05 PM
2003 Ion3 transmission swap? chantelpowell90 Ion General 11 02-15-2013 04:41 AM
transmission issues on 95 SL2 ctsv154 S-Series Tech 7 12-18-2009 10:12 PM
2002 SL1 Transmission issues, "reverse slam", P0708 code, transmission range sensor mt_spiffy S-Series Tech 20 12-14-2009 03:17 PM
