Old 06-17-2006, 09:46 PM   #1
SpeedyIon
SpeedyIon is on a distinguished road
SpeedyIon's Avatar
2004 ION-2 Quad Coupe
Default AEM CAI, Computer Reset
Is it really neccessary to reset the car's computer once a new intake is installed? I've noticed people speak about this before, but never understood the reasoning behind it.....what difference would it make?
2004 Saturn Ion-2 QC
www.ionforums.net - Forum For Saturn Ion Owners
Add to SpeedyIon's Reputation
Rate the quality of this post and help SpeedyIon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SpeedyIon is offline   Reply With Quote
Old 06-17-2006, 09:49 PM   #2
THX712517
THX712517 is on a distinguished road
THX712517's Avatar
Default Re: AEM CAI, Computer Reset
By undoing the negative battery cable from the battery and attempting to crank the car, it forces the computer to go blank. When you redo the cable, the computer is forced to immediately compensate for the new values the sensors see, rather than take a week or so to come around to the fact that the car's pulling in more air than it used to. If you're impatient, undo the battery.
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
Add to THX712517's Reputation
Rate the quality of this post and help THX712517 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
THX712517 is offline   Reply With Quote
Old 06-17-2006, 09:55 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
on my 2002 SC2, the AEM SRS instructions say to disconnect both battery cables before beginning. the PCM reset on its own since it took more than 15 minutes (or whatever the time it takes for the PCM to lose its mind) to remove the stock air box and install the SRS and reconnect the battery.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 06-17-2006, 10:02 PM   #4
SpeedyIon
SpeedyIon's Avatar
Yeah, the last time I disconnected the battery for a long time the car freaked out when I started it again. It decided to run the RPM's alot higher for the first five minutes or so with each start. It did that just about everytime I started it that day, then finally went away. I didn't even have anything electronic disconnected.
Anyways, you're saying that the computer has to adapt to the different airflow amount. Meaning that once it does it will begin putting more fuel in to compansate for the air. Correct???
Now, another question. Do these cars adapt to driving habits too?
reset computer petei Astra Tech 20 10-11-2008 06:09 PM
OBD computer reset The Student S-Series Tech 6 09-06-2008 03:58 PM
best way to reset ur computer? xupthree60 S-Series Mods 13 04-12-2007 10:51 PM
Computer Reset Uniquedolfin L-Series Tech 2 08-21-2006 05:38 PM
Computer Reset Ecator Miscellaneous Tech 5 05-02-2002 04:53 PM
