Old 08-24-2003, 02:48 AM   #1
SpeedPlayer 97sl2
SpeedPlayer 97sl2 is on a distinguished road
SpeedPlayer 97sl2's Avatar
Question Terrible Mileage, SL2
I have a 97 SL2a with about 59K miles. Over the past 1.5 months, I've noticed my mileage steadily decreasing. I went from 25 mpg, to 23 mpg, to 21 mpg, and now 20 mpg (as calculated from each gas fill up). This is despite the same driving habits, and, in some cases, an actual increase in highway mileage. If this was all short city driving, then I would understand ~20 mpg, especially since I've gotten that before under those circumstances, but all these tanks are after at least 75% highway. It just doesn't make sense. At first I attributed it to switching to Chevron gas since moving down to this region, but I have been running the latest tank back on the previous Shell, which isn't giving me any better results. The simplest things I can think of first are air filter and spark plugs, which I don't mind swapping out just to see if I get any improvement, even though they are in fine condition. I was wondering if you guys had any ideas short of me checking/replacing my temp sensors, fuel filter, etc, in case those replacements don't work...? Other than that, my car runs and looks better than most of the new cars on Saturn's lot.
Much thanks in advance.
Add to SpeedPlayer 97sl2's Reputation
Rate the quality of this post and help SpeedPlayer 97sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SpeedPlayer 97sl2 is offline
Old 08-24-2003, 09:38 AM   #2
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
Replace the PCM coolant temp sensor, it's almost as easy as changing a spark plug, and could definitely cause the poor milage you're experiencing.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 08-24-2003, 02:35 PM   #3
SpeedPlayer 97sl2
Default
Thanks for the help, Saturn-Eh. I did wonder about the ECTS, but I wasn't entirely sure, since I'm not having any overheating problems, nor does my car run, rev, or shift funny in any other way -- just poor gas mileage. I thought a bad ECTS would also cause for some other symptoms, or am I mistaken...? What about a bad intake O2 sensor? Thanks again.
My reality check bounced.
Old 08-24-2003, 03:11 PM   #4
Dr. Bob
Dr. Bob is on a distinguished road
Default
Ditto what Saturn-eh mentioned. It's the most likely cause, it's a cheap part and it's easy to replace. That's a can't lose (much) trifecta. Also check the connector and wires for corrosion and replace as needed.
Another thing to check is the engine's operating temperature. If the engine never gets to proper operating temperature, gas mileage will suffer. A common cause of this is a failed thermostat. I have a 93SL1 that had pretty miserable fuel economy which was resolved by replacing the thermostat. Mine cost $14 - genuine Saturn part.
Add to Dr. Bob's Reputation
Rate the quality of this post and help Dr. Bob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr. Bob is offline
Old 08-24-2003, 07:36 PM   #5
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
An O2 sensor can also cause the mileage you are experiencing, but would most likely turn the SES light on. the Coolant temp sensor however usually fails in a subtle way that starts with low fuel economy, followed by other symptoms later - depending on how badly the sensor has failed. As above, it's cheap, is a common failure, and likely the root of your problem.
Old 08-24-2003, 10:33 PM   #6
SpeedPlayer 97sl2
Default
Thanks for all the help folks. Much appreciated. I'll definately look into those suggestions.
Old 08-31-2003, 08:35 PM   #7
baskerj
baskerj is on a distinguished road
Default
An unsecure fuel injector would also cause the problem, but most likely you'd have a lot of shaking too. My girlfriends SL2 had the #3 fuel injector become unsecure and it got horrible gas mileage and eventually started to shake real bad. Saturn fixed it free of charge. Just a suggestion...
Add to baskerj's Reputation
Rate the quality of this post and help baskerj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
baskerj is offline
Old 09-01-2003, 05:36 AM   #8
SpeedPlayer 97sl2
Default
Nope, no shaking.
I just changed the CTS yesterday. I'll see how that goes.
I notice I keep on typing "intake" O2 sensor. What the hell is wrong with me???
Old 09-01-2003, 08:57 AM   #9
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
No worries, mate...
If you want to be technically correct, it's an Exhaust Oxygen sensor.
Cheers,
Old 09-04-2003, 04:55 PM   #10
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2006 ION-2 Quad Coupe
2002 SL1
Default
I only have 10K on mine and I feel my O2 sensor has been off since day 1 I get rough idle at times and no better than 36 mpg on my new 02'SL1 my 98' SL would get over 40 on the highway quite regularly. Saturn says that the idle is rough and thats just how 02's are they are not 98's.
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
Add to ttreibel's Reputation
Rate the quality of this post and help ttreibel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttreibel is offline
Old 10-16-2003, 04:50 PM   #11
regusr
regusr is on a distinguished road
Default
I has some really bad gas fuel mileage on my 78,000 miles SW2. Was also burning a lot of oil thinkiong that this was part of teh issue. Anyhow I added some MOA to the crqnkcase at my next oil change and the oil buring went away and gas mileage increased significantly. Give it a try...
Add to regusr's Reputation
Rate the quality of this post and help regusr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
regusr is offline
Old 10-20-2003, 12:11 AM   #12
gaddy 98 SC2
gaddy 98 SC2 is on a distinguished road
Default
whats MOA
Add to gaddy 98 SC2's Reputation
Rate the quality of this post and help gaddy 98 SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gaddy 98 SC2 is offline
Old 10-20-2003, 10:38 AM   #13
Twin_Cam
Twin_Cam is on a distinguished road
Twin_Cam's Avatar
2000 SL2
Default
I think he meant MMO, and that's Marvel Mystery Oil. Very cool stuff.....see the How-To board for more on MMO stuff.
'00 SL2m- DD, 186K miles
'05 Honda CR-V- wife's DD and my upright bass hauler
'84 Honda CB650SC Nighthawk- toy
Add to Twin_Cam's Reputation
Rate the quality of this post and help Twin_Cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Twin_Cam is offline
Old 10-21-2003, 01:49 AM   #14
ttreibel
ttreibel's Avatar
2002 SL1
Default
Synthetics helped smooth out my 95 and 02 SLones also change the airfilter it really does help
ttreibel is offline
Terrible Fuel Milage Mark T. S-Series Tech 40 01-12-2009 09:24 PM
97 SL1 terrible acceleration jpk1291 S-Series Tech 8 11-07-2007 10:15 PM
Runs terrible intermittingly tom_abb S-Series Tech 10 05-02-2007 04:21 PM
My terrible compression problems ad198592sl2 S-Series General 4 10-24-2005 06:44 PM
Terrible gas mileage pkuptrk S-Series Tech 34 01-15-2003 12:11 PM
