Go Back   SaturnFans.com Forums > Site Information > Community Center
Old 02-12-2016, 06:17 PM   #1
Stevo41788
Stevo41788 is on a distinguished road
2002 VUE 2.2L
Default 2002 Saturn vue radiator fan stays on once vehicle started
Ok we will start with the initial problem, two weeks has passed since i first notice my radiator fan was turning on as soon as i started my vehicle and not shutting off for the duration of use despite a/c and fan set to off, but shuts off when the car is off...I replaced the cooling fan high relay two days ago. not only did it not fix the issue it seems to have made things worse, now when i have the fan on (does not matter the number i set it to) it is ok. Now if i push the a/c button and turn it on (one through four) it makes my car bog down and almost kills it...( while it's idle...ie: when clutch is pushed or in neural) when driving it seems sluggish if a/c is on... just the fan on it seems to run ok...it's my first forum post anywhere for anything so hopefully i was descriptive enough any thoughts?
Add to Stevo41788's Reputation
Rate the quality of this post and help Stevo41788 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Stevo41788 is offline   Reply With Quote
Old 02-13-2016, 11:00 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2002 Saturn vue radiator fan stays on once vehicle started
There is a section for Vue's.
One possibility for constant fan run is a engine cooling sensing problem.
The ECM will operate cooling fan if there is a sensor problem as protection against overheating engine.
Have you noticed any changes in coolant gauge indication?
I'm sort of lost when your explanation moves to HVAC fan and settings 1 - 4. I don't think you're indicating these settings affects engine cooling fan - are you?
The AC compressor will "load" engine to some extent but only you will know for sure if performance has changed. Do you notice any signs of engine missing at any point?
I don't spend much time on forum but do answer private messages (they alert my phone). Include email address if you need pdf extracts. Don't use visitor message feature as I forget to check those.
How do you drain a radiator on a Saturn SC1 2002? travisj027 S-Series Tech 9 10-29-2014 07:10 PM
Radiator Fan Stays on / Coolant guage at 1/2 JosephN79 Vue Tech 3 06-17-2013 09:18 PM
Help! Car started leaking out of no where on the way home! Thinking it's the radiator SavannahMarie S-Series Tech 6 04-08-2013 06:31 PM
2002 Vue cranks, no start. Security light stays lit. Woodsman Vue Tech 21 12-26-2011 10:49 PM
Used Vehicle Review: 1996-2002 Saturn S-Series Charlie General Saturn Discussion 0 12-09-2008 08:10 AM
