Go Back   SaturnFans.com Forums > Site Information > Community Center
Old 07-20-2015, 11:47 AM   #1
cjwithey
cjwithey is on a distinguished road
Dizzy transmission problem or bad sensor? or both?
I have a 2007 saturn relay with 85,000 miles. Every now and then, it will feel like the transmission slips slightly, then the abs, traction, and stability lights come on. Sometimes the lights come on even when the transmission feels normal. Any ideas?
cjwithey is offline   Reply With Quote
Old 12-28-2015, 12:01 PM   #2
TBear
TBear will become famous soon enough
2007 AURA XR
Default Re: transmission problem or bad sensor? or both?
Hi CJ.
Your post didn't indicate if the wheels had spun... ie- driving through sand, mud, or water...
I bring this up because when I over-accelerate (thereby spinning my wheels), my dashboard lights-up like the Disneyland Electrical Parade.
It would be helpful to make a "Mental Snap-Shot" when this occurs:
ambient temperature (cold outside? hot?)
operating temperature (is the engine/trans warmed-up?... is this within the first 5 minutes of driving?)
vehicle going uphill? downhill? flat?
Taking-in some of these conditions might be helpful, when diagnosing your issue.
On a final note: maintenance! Are you due for trans. service? (filter & fluid, fluid flush only, etc)
Good luck to you!
TBear is offline   Reply With Quote
Old 12-28-2015, 11:11 PM   #3
pierrot
pierrot's Avatar
Welcome to the SaturnFans Forums, cjwithey, it's a useful and helpful site!
I'd like to suggest a couple of things relative to posting this issue here in the forums:
1st) Re-post this message in the RELAY Tech Forum. You can do this by using the quote feature, copying all of the contents appearing, then paste it on to a new message posted in that forum. You're likely to get better help from members who post there.
2nd) Be sure to add your vehicle's maintenance history, especially with regard to the transmission.
If you've ever seen a "wrench" warning light appear and remain on - or a warning light other than the CEL or Service Engine Soon - at the dash console after this event happens then please mention it.
334,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
Automatic Transmission Fluid Change...sensor wire problem flyhop S-Series Tech 7 08-05-2011 07:07 PM
Transmission sensor? hit_n_run S-Series General 13 06-11-2011 10:51 PM
2002 SL1 Transmission issues, "reverse slam", P0708 code, transmission range sensor mt_spiffy S-Series Tech 20 12-14-2009 03:17 PM
Acceleration problem...gets stuck...possibly transmission? Or a gas problem? Dingo Warrior S-Series General 34 03-29-2009 01:20 PM
