Old 06-03-2007, 05:50 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Installed new OEM shifter cables and it seems so stiff to shift
Today I installed my OEM shifter cables and when test driving, it seems so stiff to shift..It goes in gear but very tight..My old taiwain cables when into gear very easily..With my new OEM cables going into first gear is sometimes hard to get into gear..Is this normal? I looked everything over and everything went in straight and connected properly..I also put lithum grease on the cables..Are new OEM cables that stiff when shifting? Is it stiff because the cables are new? Will it loosen up as time goes by?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 06-03-2007, 07:16 PM   #2
dmc
dmc is on a distinguished road
2000 SL2
Default Re: Installed new OEM shifter cables and it seems so stiff to shift
Maybe you can try greasing up the linkage on the transmission?
Add to dmc's Reputation
Rate the quality of this post and help dmc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dmc is offline   Reply With Quote
Old 06-03-2007, 10:55 PM   #3
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Make SURE that your cables are not sitting in the shifter on an angle.. and that the cables are pulled through the grommet into the CABIN enough that they CURVE around the floor.. NOT at an angle at the shifter.
And it may get easier as the cables break in.... but it was a lot EASIER for me when i installed the new OEM cables.
edit: could be your synchro's like mine.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 06-04-2007, 12:08 PM   #4
turbobuick33
1992 SL2
I pulled the cables from the inside and it moved in a little bit..The cables do sit and are curved around the floor, on the left side..But theres no improvement in the shifter, still stiff. I also lube up the shift tower and no improvement..I took some pics..Everything to me looks good but I don't get it why it's so stiff to shift...I am afraid that this stiffness when shifting might cause stress on the eyelet and it might pop put again on me without any warning.
I don't think it's my synchro's at all, my old taiwain cables I was able to shift into first gear easily and all other gears with ease and now shifting is stiff with the OEM cables.
Has anyone else experince stiff shifting after installing new OEM cables? Is this a NORMAL or not normal feeling when you install new OEM cables?
92 SL2, 5 speed
91 Lx 5.0
Old 06-04-2007, 12:49 PM   #5
BarnOwl
BarnOwl's Avatar
I installed a new OEM shift cable on my '96 and I didn't notice any difference in shifting.
Add to BarnOwl's Reputation
Old 06-04-2007, 01:49 PM   #6
Are both left-right and fore-aft movements difficult?
IIRC, the two cables are different. Are you sure you put the right cable in the right position? (I may be wrong on the premise, here, though....)
Add to madpogue's Reputation
Old 06-04-2007, 02:44 PM   #7
turbobuick33
1992 SL2
Going left into first is sometimes hard to get into..In neutral the shifter moves fine with ease left and right..What do you mean when you say putting th cables in the right position?
I connected the cables properly..The white one goes on top on the shift tower and the black one goes to the bottom on the shift tower..Is their a certain postion that it's supposed to be when it goes thru the engine to the shift tower?
Shifting now is not as ease as before..It's totally weird! I wasn't epecting this at all..I was expecting the same results as I had with my taiwain cables and now it's stiff to shift and not confortable..I am stumped and I don't know what to do now.
92 SL2, 5 speed
91 Lx 5.0
Old 06-04-2007, 04:49 PM   #8
I was just wondering if you'd installed the left-right cable where the fore-aft cable should go, and vice-versa. Sounds like you got it right.
If L-R movement across neutral is easy, then that cable is not an issue.
Try this: disconnect the fore-aft cable from the shift tower, and see how hard it is to move the shifter fore and aft. If that's difficult, reconnect it, and disconnect it from the shifter, and try just moving the cable by hand from the shifter end. These two tests should shed some light on where the difficulty can be located.
Old 06-04-2007, 05:13 PM   #9
turbobuick33
1992 SL2
Is the fore-aft cable on the shifter tower the top white cable?
92 SL2, 5 speed
91 Lx 5.0
Old 06-04-2007, 05:45 PM   #10
Just going by memory, no, the fore-aft cable is the lower one. But you'd have to work the shifter and watch the cable movement under the hood to be sure (an assistant would be helpful, of course).
Old 06-04-2007, 09:20 PM   #11
andy_95sl2
andy_95sl2's Avatar
this is soo strange... Watch the fore-aft cable (the one on the right side.. more specifically the black one) and see if there's any binding. If needed, i have an extra set of taiwan cables i can sell you for cheap
Old 06-04-2007, 09:21 PM   #12
andy_95sl2
andy_95sl2's Avatar
Just wondering... do you have an SZP Racing short throw shifter? If so, the shifter needs to be shimmed UPWARDS because the bottom portion of the shifter has been elongated, throwing the cables at an awkward angle.
Old 06-04-2007, 10:16 PM   #13
turbobuick33
1992 SL2
Yes I do have an sps short throw shifter, I had to replace the shifter nipple on it because I had the metal bushing on it so I used my stock nipple from my stock shifter and I bolted it, not tight at all so there will be movement and pivot action...WHat exact part on the shifter needs to be shimmed upwards? WHat do I use to shim it?
I have used this shifter on my taiwain cables and it shifted with ease, I don't understand why the OEM cables are giving me a hard time?
92 SL2, 5 speed
91 Lx 5.0
Old 06-05-2007, 07:43 PM   #14
turbobuick33
1992 SL2
bump^^ how do I shim my shifter?
92 SL2, 5 speed
91 Lx 5.0
transmission, clutch, shifter, shift cables? help please sc2dohc94 S-Series Tech 11 11-12-2008 03:44 PM
Saturn manual shifter cables sucks! Shifter eyelet came off turbobuick33 S-Series Tech 22 05-28-2007 04:10 PM
Key Stuck In OFF Position //Shifter Stiff in P CND_SC1 S-Series Tech 13 08-06-2006 12:01 AM
The shifter is terrible and stiff lovemysan S-Series General 4 05-22-2006 01:39 PM
Shifter still feels sticky, even after new shifter and cables! 98greenSC2 S-Series Tech 6 11-22-2005 09:15 PM
